Headlight Question - Proper re-sealing? Rubber Surrounds?
Old May 25, 2008 | 12:46 PM
richardsc's Avatar
Guest
Default Headlight Question - Proper re-sealing? Rubber Surrounds?
Take a look at my other thread, <a href="https://forums.audiworld.com/a6/msgs/789262.phtml">https://forums.audiworld.com/a6/msgs/789262.phtml</a> to see what I've been doing. I've gotten the lights put back together with a fair dose of silicon, but I have a couple questions for anybody who's taken their lights apart:
1) When I took my lights out, the rubber "surround" that runs around the top and sides of the light housings basically fell apart on both lights. they are in pieces. Are they imperative to have on the car? If so, does anyone have a source for them? I can't seem to find them online at all.
2) Did you run another bead of silicon around the lens after you assembled the lights to keep moisture out? I've been considering this, but IF I have to take them apart again later, it's going to be a PITA!
Thanks for any info,
Charles
Old May 25, 2008 | 03:05 PM
Reifle's Avatar
It is aweather stripping actually - keeps the muck and moisture out - try a dealer couldn't to $$
Old May 25, 2008 | 05:21 PM
mpw's Avatar
mpw
Rubber trim is $34.76 each thru AudiPartsDepot.com w/AW discount
Old May 25, 2008 | 08:36 PM
richardsc's Avatar
Guest
Thanks for the info and link to the website. How do you get the AW discount?
Old May 26, 2008 | 05:18 AM
mpw's Avatar
mpw
Default Here's the link...
<ul><li><a href="https://forums.audiworld.com/a6/msgs/783835.phtml">click</a></li></ul>
Biggeek
9
Jan 1, 2007 09:00 PM
DB/S4
15
Oct 4, 2006 11:34 AM
go2fast
Feb 24, 2005 09:23 AM
eroc
Dec 29, 2002 04:06 PM
Liam in Montreal
Aug 23, 2001 03:20 PM
