also- is there a trick to taking the friggin tires off once all five lugs are out?
Old May 25, 2008 | 01:28 PM
TurboRambo's Avatar
New Member
Default also- is there a trick to taking the friggin tires off once all five lugs are out?
thanks
Old May 25, 2008 | 01:30 PM
TurboRambo's Avatar
New Member
^^^Disregard this post (I searched the archive) but an answer is still needed here \/ \/ \/
Old May 25, 2008 | 02:21 PM
Robin@Revo Technik's Avatar
Former Vendor
Default set the car down off the jack and let the weight of the car break the wheel loose.
They can corrode together over time.
Old May 25, 2008 | 05:16 PM
5speed6  v.2's Avatar
Member
Default When it rains for everyone else, it pours for you, huh?
Did you get your wheels off?
Old May 26, 2008 | 12:14 PM
R2.7TA6's Avatar
Member
yes, coat hub with some anti-sieze before installing wheels
Old May 26, 2008 | 02:59 PM
WOWDee's Avatar
Default grab tire with both hands 180 degree apart, rock, rotate 90 degrees>
repeating .... usually i can dislodge the wheel by the time I make one revolution of the tire .... you really gotta put some muscle into it .... so make sure you have it on jack stands.
vkamnyev
A4 (B9 Platform) Discussion
10
May 11, 2018 02:49 AM
vb9594
A4 (B7 Platform) Discussion
Mar 2, 2006 11:12 AM
Silver_Patrone
Audi A3 / S3 / RS 3
Feb 15, 2006 10:54 AM
Alf Arkin
Nov 1, 2003 06:43 AM
