Pass side front axle fixed, but noticed another issue.
If this is the case it will require removal of the diff and a new output shaft fitting.
I would remove the flange from the box and see what is wrong. It may be possible to pack it with some resin based compound then tighten it up and hope it holds!
As you can see from the above picture, my flange does not have a center bolt, as some do.
I'm not sure how to remove it? Maybe I just pull? If so, maybe that's the problem and why there is so much play? Maybe I accidentally pulled it out (partially) when I was attaching/wrenching on the control arms and upright during the install.
i remember briefly having the same thought go thru my mind when I was reinstalling the trans ... but quickly dismissed it as normal with all that goes into a reinstall I didn't have much time to think about it... it works fine so I am not worried about it.
Now if you can pull out or push in on the flange (axial play) I would say there is something wrong ... or if there was some really excessive rotational play or associated unusual feel or sound associated with it .... you could possibly have a problem.
