paging 5SPEED6 where is the vss wire in our cars?
Old May 27, 2008 | 12:18 PM
blAck6 (desairs)'s Avatar
Old May 27, 2008 | 01:24 PM
Boston Driver's Avatar
AudiWorld Expert
Default Assuming you are asking for GALA speed signal, it is in the blue 32-pin connector...
...behind the instrument cluster, pin #3 which is a white/blue wire.
Old May 27, 2008 | 01:25 PM
5speed6  v.2's Avatar
Member
Default If your car had factory NAV, it's in the rear drivers side quarter...
...if not, there are several ways of catching it.
You can get it from the ABS module, or you can get it from the cluster.
You can also can use a CAN breakout module if you want to interface steering wheel controls, but that is the expensive route.
Old May 27, 2008 | 01:32 PM
AudiWorld Expert
Was factory nav available with the 3.0? Just curious.
Old May 27, 2008 | 01:35 PM
txag_a6's Avatar
Yes, it was.
Old May 27, 2008 | 01:41 PM
Member
Available on All models.
Old May 27, 2008 | 02:03 PM
so where can i get a can breakout module and what does it do?
Old May 27, 2008 | 02:29 PM
Member
Default You can read up on it here...
<center><img src="http://www.soundgate.com/upload//productimages/0794."></center><p><ul><li><a href="http://www.soundgate.com/index.php?request=product.details&amp;categoryid=2 62&amp;productid=590&amp;usereferrer=1&amp;">Click </a></li></ul>
 Pouria Savadkouei
 Michael S. Palmer
Old May 27, 2008 | 02:46 PM
is there a cheaper way to keep the steering controls?
Old May 27, 2008 | 02:50 PM
Member
Default There are two other companies who make those modules...
...but the end cost winds up about the same.
TighTT
NY / NJ / CT Discussion
May 8, 2008 12:47 PM
a4tisâ„¢[Bye Turbo]
Apr 30, 2006 01:47 PM
Thorsholm A4 tdi
Nov 1, 2005 04:11 AM
salpinx
May 2, 2004 02:23 PM
02amulet
Dec 11, 2003 07:36 AM
