so i need everyones opinion. Is it worth the $300 just for steering controls?
Old May 27, 2008 | 05:44 PM
blAck6 (desairs)'s Avatar
Old May 27, 2008 | 05:49 PM
5speed6  v.2's Avatar
Member
Default My .02.... I can't live without them. Been using them since day 1, and..
...whem I went aftermarket, I refused to lose that functionality.
Old May 27, 2008 | 05:50 PM
Member
Default Oh...if you just want the SWC funtionality without VSS, the 2 PAC modules...
...will run you about $150
thats how i am but i got to thinking, what if i get a paddle shifter wheel, hmmmm
Old May 27, 2008 | 05:51 PM
oh then maybe ill just do that. how hard are they to wire, and where would i wire them
Member
Default I've had the opportunity to get the 3-spoke wheel many times....
...turned it down, as I don't want to give up the remote radio controls.
Old May 27, 2008 | 05:55 PM
Member
Default Once you do the breakout with the wire harness adapter, you will have..
...a CAN Hi, and CAN Lo wire. That goes into the CAN BUS adapter. That CAN BUS adapter direct plugs into the steering wheel interface adapter and connects to the Pioneer's remote control wire.
You will also need 12volts and ground to these adapters, but that is not hard, as you will have the radios power and ground wires in the breakout.
Old May 27, 2008 | 05:57 PM
cool thanks
 Pouria Savadkouei
 Michael S. Palmer
Old May 27, 2008 | 05:59 PM
Member
You're welcome.
Old May 27, 2008 | 06:08 PM
audikillsbmw's Avatar
Member
Default Exact opposite for me. I'd love to have a 3-spoke, and I don't mind losing the
radio controls.
