Front central Armrest......
Old May 28, 2008 | 08:26 AM
raddox's Avatar
Default Front central Armrest......
latch problem...well the spring (I think) is broken. I have done some searching but I may be using the wrong key words. I used "armrest" and "latch" but I get mostly posts about the rear armrest. Any hints? I am going to check the tech pages here in a moment. My apologies if I completely over looked a previously written discussion.
Thanks,
Old May 28, 2008 | 08:53 AM
Boston Driver's Avatar
AudiWorld Expert
Default Is it stuck closed and you cannot open it, or will it not latch shut?
either way, you are probably going to have to replace it. Not sure if there is a handy DIY repair on the latch for the armrest cover.
Dealership will charge you $$$. Best to find one from a parts recycler (www.car-parts.com).
What year and color?
Old May 28, 2008 | 08:58 AM
raddox's Avatar
Default it will no longer latch shut
It will latch but I remember it being somewhat springy...if that makes sense. Right now I have to kind of push the latch down so that it catches. So I am thinking that the spring in there popped...so I want to try and fix it without replacing the entire armrest.
Old May 28, 2008 | 08:59 AM
raddox's Avatar
Default Re: Is it stuck closed and you cannot open it, or will it not latch shut?
Sorry dude...didn't read the entire post....2002/black.
Old May 28, 2008 | 09:16 AM
AudiWorld Expert
Default Hmmm...maybe...
...you can remove the armrest so you can look closely at the latch mechanism. It is not too hard to remove (see link below for how to remove it). Perhaps a good cleaning is all it needs
As far as repairing it, I do not recall anyone ever trying. Internal armrest parts are not available separately, so usually the whole armrest is replaced if broken.<ul><li><a href="https://forums.audiworld.com/a6/msgs/388068.phtml">...how to remove the armrest...</a></li></ul>
Old May 28, 2008 | 09:59 AM
raddox's Avatar
Default Thanks BD..
I appreciate all the help man.
Old May 28, 2008 | 10:44 AM
02 Silver Arrow's Avatar
mine deoes the same thing. I looked and have since decided to live with it
Old May 29, 2008 | 03:00 PM
OneGuyInCA's Avatar
Default Look at my write up on the airbag module... procedurally will
show you how to remove the armrest.
 Pouria Savadkouei
 Michael S. Palmer
saxman42
Q7 MK 1 Discussion
Apr 6, 2019 03:29 PM
mcdream
Q7 MK 1 Discussion
Aug 20, 2013 12:12 PM
canaudinut
Nov 4, 2006 08:36 AM
stangman05
13
Jan 18, 2006 11:16 AM
valium
Apr 14, 2003 06:51 AM
