oil light coming on
other possibility - oil pump / cooler
or maybe a flow problem ...but hopefully not ... chances are it is something simple .... but with my luck usually not.
hows the oil temp?
sometimes the oil drain holes under the valve cover gaskets got plugged on my older cars ... oil would pool and give me this symptom ... however by the time I shut her down and checked the oil she would look ok ..... solved the problem the next time i had the valve covers off to replace leaky gaskets by running a coat hanger down the drain holes to clean out the sludgy oil deposits that kept the oil from draining back to the pan ... usually doesn't happen until higher milage though ..good luck!
