Rattling when turning right at highway speed
Old May 29, 2008 | 08:46 PM
sam08861's Avatar
Default Rattling when turning right at highway speed
Hi,
I just went on a 1hr road trip yesterday and on the return journey, noticed a rattling sound and vibration when turning right. It seemed to be less when going straight or turning left.
This doesn't happen at lower speeds, but above 55-60mph.
Any ideas of what to check? I'll get the car jacked up tomorrow to try and move the wheels a bit to check the bearings, tie-rods, ball-joints. I just had all these changed about a year ago, so hope it's not that fun/expense again.
I've never worked on an audi, but know my way around the porsche suspensions, which are way different setups. (for one, I can see the suspension components, here everything seems to be hidden behind sheet metal.)
I've heard there are some 10mm 12pt bolts underhood under the battery that might be problematic.
Old May 29, 2008 | 09:03 PM
iProDrive's Avatar
Default Your "STFA" was correct...I was the original poster about the bolts for the steering rack...
<a href="https://forums.audiworld.com/a6/msgs/670657.phtml">Steering Rattling Issue</a>
Old May 30, 2008 | 05:46 AM
hardeejr's Avatar
Default You had the issue with the 2000 A6...
Did you check your 04 after finding the problem with your 00? Reason I ask is I've got an 04, and was wondering if the rack is the same - or if there have been any reports of a 2002-2004 with the issue.
Old May 30, 2008 | 12:15 PM
iProDrive's Avatar
I haven't checked my '04 yet, pretty sure they are the same...
Old May 31, 2008 | 05:31 AM
WOWDee's Avatar
Default Only make left turns - could be worn brake pads loose in the cals>
i've chased problems like these before ...only to never find them ...and then to have them disappear months later when i finally do a brake job
Craig3Q
Audi A3 / S3 / RS 3
Apr 29, 2008 09:27 AM
JRingham
Audi allroad
Sep 18, 2007 05:12 AM
JMS-Four
Pacific Northwest Discussion
15
Apr 24, 2007 05:15 PM
SimonG
Sep 26, 2005 09:46 AM
Thorsholm A4 tdi
Oct 10, 2003 08:53 AM
