Calc (inside) shows very little extra power/torque required for 12 lb heavier wheels
My detailed calcs are as follows:
My tire/wheel combo weighs 53 lbs (found from STFA). I looked at tire rack and a 235/45/17 tire weighs 22 lbs like my 235/40/18. So my wheel weighs about 31 lbs.
BD has lightwieght Volks wheels that weigh 18.5 lbs (per a previous post by him), therefore I could save about 12 lbs by changing wheels and little/no weight by changing tires.
I estimated that the center of mass of the extra weight of my wheels "acts" at a radius of 2/3 of the wheel radius or about 6" from the centerline.
The formula for the moment of interia (I) is 0.5*m*r*r where m is weight in lbs (12 lbs) and r is 0.5 ft (6 inches). This gives a moment of inertia of 1.5 lb-ft-ft.
Torque (T)is T=I*alpha/g where alpha is angular acceleration in radians/sec/sec and g is acceleration of gravity or 32.2 ft/sec/sec.
If you're still reading, then hopefully you are still following this.
Angular acceleration is calculated as follows.
Initially, it's zero at stop.
A 235/40/18 tire has approx 800 rev/mile, so at 60 miles per hour, it has 48000 rev/hour or 13.3 rev/sec.
If my car can accelerate from 0 to 60 mph in 6 seconds, then the angular acceleration is 13.3 rev/sec divided by 6 sec or 2.22 rev/sec/sec (assuming constant acceleration).
There are 2*PI radians in one revolution, so angular acceleration is 2*PI*2.22 = 14 rad/sec/sec.
Therefore the torque required to spin 12 lbs located 6 inches from axle from stop to 60 mph in 6 sec is
(1.5 lb/ft/ft)*(14 rad/sec/sec)/32.2 ft/sec/sec which equals 0.65 ft-lb. Multiplying by 4 wheels gives 2.6 extra ft-lb of torque.
To translate into horsepower, we need to know the average angular speed of the wheel. If acceleration is constant from 0 to 60 mph, then the average angular speed of the wheel occurs at 3 secs (half way between 0 and 6 sec) and is
(14 rad/sec/sec)(3 sec) or 42 rad/sec.
HP = Torque*angular speed/550 or
HP = (2.6 ft-lb)*(42 rad/sec)/550 = 0.2 HP
Any (constructive) comments?
I'm more concerned about torque than HP as that's what makes the car giddy-up.
So, total torque increae req'd would be 2.6 lb-ft x 4 = 10.4 lb ft. For my car (2.7T) that is roughly 3.8% of torque available.
Did I figure this right?
The tire mass > wheel mass. And most of the wheel mass is in the rim itself, and the hub, or so I presume from appearances. So I'd place it much further out.
Did you do a delta vs standard wheels/tires? I didn't see it in my scan. So you got the power to drive the wheels, but not the change vs a different wheel/tire. What you have is vs no tires at all, which i would predict to generate less forward motion - call me crazy.
Nice job. You do in fact have too much time on your hands.
G
