Help! Which O2 sensor do I have? 3 or 4 wire?
Old May 31, 2008 | 09:19 AM
98Quattro's Avatar
Default Help! Which O2 sensor do I have? 3 or 4 wire?
I have a 98 2.8L Quattro. NOt sure which one I need and I need to have my pre-cats replaced.
Thanks.
Old May 31, 2008 | 09:38 AM
JoeCaymanBWI's Avatar
Default Good luck | I had the same post 3 days ago and no reply.
I went to my Audi Advisor and asked.
My 02 3.0 O2 Sensor has 5 wires - $245.00 each. OUCH.
Old May 31, 2008 | 10:30 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Kind of a silly question, IMHO.
Who cares how many wires it has? Oxygen sensors, like all parts, should be purchased based on part number. All four wire sensors are not the same.
Old May 31, 2008 | 10:31 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default "I need to have my pre-cats replaced."
Where are you located? No pre-cats on any US model 1998 Audi's.
Old May 31, 2008 | 10:38 AM
98Quattro's Avatar
Default It does matter how many wires it has....
A 3 wire O2 sensor won't plug into a 4 wire connector and vise-versa.
And according to every site out there...my 98 2.8L has 2 pre-cats and 2 post-cat O2's.
Old May 31, 2008 | 10:40 AM
4Driver4's Avatar
Tech Guru
Tech Guru
OH! You mean pre-cat O2 sensors. Got it. Again, go by part number, not wire number.
Old May 31, 2008 | 11:05 AM
frankinstyn's Avatar
Default Re: Help! Which O2 sensor do I have? 3 or 4 wire?
That depends on whether you have the AHA or the AFC engine. The 30v newer engine is most likely (AHA) in which case you need the four wire oxygen sensor.
You can purchase them new here for about $100 for the front and $130 for the rears. Be sure to read the description as while they are interchangeable in the front, they are not in the rear (side to side I mean)<ul><li><a href="http://www.autohausaz.com/search/product.aspx?sid=gwtmxdu4435dzs554ablw0em&amp;make id=800002@Audi&amp;modelid=1313513@A6%20QUATTRO%20 &amp;year=1998&amp;cid=oxygen@oxygen&amp;gid=5132@ Oxygen%20Sensor">Autohausaz - 1998 Audi A6 Quattro
Old May 31, 2008 | 11:20 AM
98Quattro's Avatar
thanks so much....I have the AHA engine so I need to get the 4 wire o2 then....Thanks.
 Pouria Savadkouei
 Michael S. Palmer
Old May 31, 2008 | 12:00 PM
Correct | if you replace the pre or post - make sure you replace both of them and not just one.
Old May 31, 2008 | 12:02 PM
Default Where are you getting the 02 sensors? I guess you need to get the "PART NUMBER"-some ppl here are...
............................................ugh!
