broken springs
Old Jun 2, 2008 | 05:55 PM
glostah's Avatar
Default broken springs
This is a 99 a6 quattro wagon.
I've been replacing my front end with a control arm kit that I bought from autoparts warehouse, so I'm doing both sides with upper and lower control arms, tie rod ends, linkages and sway bar bushings. On the driver's side I ran into a bad cv boot, so I'm replacing the axle. I then had a real problem with the upper control arm pinch bolt, forcing me to remove the spindle so a could take it to a machine shop and have the bolt pressed out (I'm only willing to go so far with a BFH and mapp gas). Anyhow, with the driver's side nearly completely disassembled I had a chance to really inspect the spring and noticed it was broken. I checked the passenger side and found the same problem - explaining the reason why all my control arms and bushings were screwed up.
So now I have the spring/strut assemblies removed from the car,and out of the bracket that holds them in place at the top of the wheel well. How do I proceed from here? Do I need a special tool to remove the spring from the strut? Should I replace the struts as well? Any advice is greatly appreciated.
Old Jun 2, 2008 | 06:24 PM
MikekiM@PureMS's Avatar
Former Vendor
Default There are 2 13mm nuts on the top of the top bracket.
That will separate the shock/spring assembly from the top control arm housing.
The spring then needs to be compressed, and the top single 18mm nut can be removed safely.
Assembly is the reverse.
On a '99, Im betting the shocks are well past their useful life and probably should be replaced with the springs.
Old Jun 2, 2008 | 07:00 PM
glostah's Avatar
Default Thanks. I didn't know about the spring compression tool
I'm glad I asked!
prestonian
Audi Original "S" Cars
13
Sep 4, 2012 08:26 PM
HIS4
Jul 21, 2008 11:10 AM
Mr.88-80Q
Oct 27, 2005 12:21 PM
Mr. Head
Feb 8, 2005 05:45 PM
rmr25
Aug 14, 2004 09:06 AM
