My car did several weird things today but one kind of spooked me...
Old Jan 6, 2009 | 06:48 PM
audimonster100's Avatar
New Member
Default My car did several weird things today but one kind of spooked me...
Firstly the brake pad light came on and I just replaced them in August and have only put about 4000 miles on the car since. I am almost positive it is the connectors or something of that nature I'll pull everything apart this weekend when I do the oil change. But the most important one is that when I went out to my car tonight, after I started it up it beeped and the ABS light came on and the brake light was flashing. It went out after about thirty seconds. Should I be worried or was this just a hiccup. Thanks for your help,
Old Jan 6, 2009 | 07:01 PM
TXurS6's Avatar
Did you check the brake fluid level after you changed the pads?
Old Jan 7, 2009 | 02:55 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Time for an ABS control module repair.
Old Jan 7, 2009 | 02:59 AM
Grapeking's Avatar
25 Year Member
2nd. Good thing is it is reasonably inexpensive, and easy to do.
Old Jan 7, 2009 | 03:49 AM
New Member
Default Yes, the guy I bought the car from overfilled it so when i pushed the calipers back in
it came out the top of the brake fluid reservoir. I'll check it again just to make sure.
Old Jan 7, 2009 | 03:50 AM
New Member
Is the car driveable right now or should I refrain if possible.
Old Jan 7, 2009 | 03:54 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Drive it, but know that ABS and EDL are not functional when the lights are on.
This affects quattro, brake bias and anti-lock.
STFA for "module master" or "BBA". Both are good, but it makes sense to use the one closest to you. MM has a good video on removing the ABS control unit to ship it in for repair.
Old Jan 7, 2009 | 06:03 AM
OOOOya's Avatar
Default ABS long shot
My S6 started acting up this past summer several days in a row. The ABS would cycle a few times and then the light would come on & stay on. I "fixed" it by disconnecting, examining, blew out minimal debris, and reconnected the ABS controller under the hood.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 7, 2009 | 07:44 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Since the problem is an internal open, that might work short term.
But the problem is still there should probably be repaired.
Old Jan 18, 2009 | 08:30 AM
sidespar's Avatar
send me an email if you want your module repaired.
ModifiedA4
Sep 25, 2006 12:49 PM
Asicks2.7T
11
Dec 19, 2005 12:46 PM
Toronto A4 guy
Jun 13, 2005 04:45 AM
'00 Santorin S4
Feb 24, 2004 08:16 PM
TonyDetroit
Jan 10, 2004 10:48 AM
