1999 A6 2.8Q with slipping tranny shifts...
Old Jan 9, 2009 | 08:24 PM
Boston Driver's Avatar
AudiWorld Expert
Default 1999 A6 2.8Q with slipping tranny shifts...
I met a "new" owner of a 1999 A6 2.8 with 221k on the odometer recently. Helped with the throttle body adaptation, but the car has an odd shift when driving. It will seem to rev a bit higher between shifts (like the car is in neutral for a second), then slam into the next gear. We tried the tranny adaptation several times (manually and with the VAG COM), but no change in behavior.
The only error code that comes up is:
00526 - Brake Light Switch - F
27-00 Implausable Signal
Thoughts? Bad tranny??? TIA for any thoughts.
Old Jan 10, 2009 | 04:03 AM
paulroad's Avatar
Tech Guru
my first thought is tranny fluid.. not just level, but age.
Old Jan 10, 2009 | 04:04 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Low fluid. Almost always.
mikethomp
Audi 100 / A6 (C4 Platform)
Jun 15, 2008 08:19 PM
300diesel
Dec 13, 2005 08:31 AM
SoCal Avanti
Oct 12, 2004 09:06 AM
snakebit68
Mar 23, 2004 08:44 AM
audimotion
Dec 15, 2001 06:38 AM
