Got a 17748 : Cam vs Crank Sensor not correlating - I'm stumped down to last option. Suggestions ?
Old Jan 11, 2009 | 01:16 AM
VR_Life's Avatar
Guest
Default Got a 17748 : Cam vs Crank Sensor not correlating - I'm stumped down to last option. Suggestions ?
2.7T runs very rough after having head gasket replaced, and heads cleaned.
Group 93 shows Bank 1 Phase = 17~25kW, while Bank 2 Phase = 2kW
Did the group 94 test, failed on Bank 1.
So I :
- Checked the Cam/Chain (links between teeth are correct, sprockets exactly aligned at TDC)
- Redid the T-Belt
- Replaced the Bank 1 Cam Pos Sensor
- Swapped the Bank 1 vs Bank 2 Cam Tensioner solenoid
=> No change in symptoms
Only thing I can think of left is to replace the entire Tensioner assembly - seems higly unlikely.
Any other suggestions ?
Old Jan 11, 2009 | 04:10 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default What are you using to align the belt?
Is it possible that cam tensioners were swapped? IIRC, they are different.
Old Jan 11, 2009 | 10:20 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Is the sensor in the tensioner on a 2.7t head? It's not on the 2.8...
Old Jan 11, 2009 | 11:15 AM
VR_Life's Avatar
Guest
Default Using the real tools : Crank Lock Pin + Cam Locking bar
Left the cam sprockets bolt loose & untorqued while re-installing the belt. Pre-Tensioned it correctly, torqued and then cranked it to see if it still lined up. Verified the Cam alignment marks. It was/is perfect.
Swapping tensioners ? I'll check - it's unlikely the shop doing the heads could have done that. But I'll check.
dakinejb
Feb 15, 2017 11:55 PM
Moosipher
1.8T Discussion
May 30, 2016 05:39 PM
TwinTurboTerror
Jul 7, 2006 04:14 AM
VAP
13
Jun 11, 2006 04:39 PM
