Headlamp Restoration Project
Old Jan 11, 2009 | 03:19 PM
OneGuyInCA's Avatar
Default Headlamp Restoration Project
Just got done restoring the headlamp on my car. The plastic had significant amount of scratches, blemishes, and UV damage on it. I used the 3M Headlight Lens Restoration System kit. Works like a charm. Here are a couple of before and after photos. I'm quite pleased with the results.
I notice that there's already an article in the resource section for resurfacing the headlamp... but if anyone is interested, I can write up my experience using this particular 3M kit.
BEFORE:
<img src="http://www.estatephotography.com/audiworld/headlamp/5.jpg">
<img src="http://www.estatephotography.com/audiworld/headlamp/7.jpg">
AFTER:
<img src="http://www.estatephotography.com/audiworld/headlamp/20.jpg">
<img src="http://www.estatephotography.com/audiworld/headlamp/16.jpg">
Old Jan 11, 2009 | 03:25 PM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Looks great! Did the 3M kit have a UV-resistant clearcoat?
Old Jan 11, 2009 | 04:28 PM
JimmyC83's Avatar
Default nicely done. was it cheaper than the method i followed?
Amber is a sign of weakness
Old Jan 11, 2009 | 04:39 PM
Stoney's Avatar
Tech Guru
Beautiful! If you have anything to add, at least product specs, that would be useful, I'm sure.
Old Jan 11, 2009 | 04:44 PM
Press's Avatar
Fear the Miata!
beautiful....nice job
Old Jan 11, 2009 | 05:00 PM
OneGuyInCA's Avatar
Default Here's a photo step-by-step
<img src="http://www.estatephotography.com/audiworld/headlamp/1.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/2.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/3.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/4.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/5.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/6.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/7.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/8.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/9.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/10.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/11.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/12.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/13.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/14.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/15.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/16.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/17.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/18.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/19.jpg" />
<img src="http://www.estatephotography.com/audiworld/headlamp/20.jpg" />
Old Jan 11, 2009 | 05:01 PM
OneGuyInCA's Avatar
Default Not sure how much the other way costs... but the 3M kit cost me $21.48 shipped
from TCP Global.
Old Jan 11, 2009 | 05:02 PM
OneGuyInCA's Avatar
Default Not sure... but per the instructions... to use a good
plastic polisher once in a while to maintain the shine/clearness.
 Pouria Savadkouei
 Michael S. Palmer
A6Turbo2.7t's Avatar
Member
Default I did it the old fashioned way - where'd you get the kit??
The method was in the archives using 600, 1500 and 200 grit sandpaper and plastic polish. Worked like a charm, but I forgot to do pics
Old Jan 11, 2009 | 05:04 PM
OneGuyInCA's Avatar
Default Probably the best part of using this kit... is that
using a drill to sand certainly speeds things up quite a bit. Doing both headlamps took about 45 minutes.
I did add in one extra step... which is to use a rotary polisher as a last step to really shine things up.
