need P/N help - latch for rear folding seat
Old Jan 12, 2009 | 06:08 AM
Asicks2.7T's Avatar
Default need P/N help - latch for rear folding seat
The latch that locks down the single rear folding seat (behind driver) has failed on me. it will no longer click into place when you close the seat. I fold this seat down a lot when I load my snowboard into the car so I suppose it gets more use than normal.
I have sport seats from a certain someone's 2002 4.2 (if that makes any difference). does anyone have experience with replacing these? I figured since you're dealing with the upholstery it might be tricky.
Old Jan 12, 2009 | 06:15 AM
Boston Driver's Avatar
AudiWorld Expert
Did you try to adjust the post instead? Are you sure it's the latch???
Old Jan 12, 2009 | 06:26 AM
Asicks2.7T's Avatar
Default hmm...
i didn't think to try that. if i remember correctly it has an allen wrench head on it? I'm sure it could be loosened but how exactly do I adjust it? the latch just wont "click" into place anymore. after I shut the seat, I can fold it down again without having to pull the handle. and it rattles like crazy while I'm driving...
Old Jan 12, 2009 | 06:36 AM
AudiWorld Expert
Default you can adjust it by hand if you loosen the 17mm locking nut...
<img src="http://img.photobucket.com/albums/v739/hliu55/rear%20seat%20swap/rearseat7.jpg">
Old Jan 12, 2009 | 06:48 AM
AudiWorld Expert
Default ...also, have you checked to make sure the two screws for the latch are intact???
<img src="http://img.photobucket.com/albums/v739/hliu55/rear%20seat%20swap/rearseat9.jpg">
<img src="http://img.photobucket.com/albums/v739/hliu55/rear%20seat%20swap/rearseat10.jpg">
I recall having some issues lining up one fo the latches when we installed your seats in the comfort of Billy's shop. We had to swap out the rear latches so the key would still lock the seats if needed.
Maybe we can take a look at it sometime soon? You around at all, of stuck up in NH???
Old Jan 12, 2009 | 08:56 AM
02 Silver Arrow's Avatar
Default LOOSEN DON"T REMOVE the nut, but BD is correct about the adjustment
it's a PIA I messed mine up when I removed the panel not thinking about this adjustment deal. The seat had the same symptons you are talking about. you will have to use trial and error. adjust try, repeat. Once I got it to latch I stopped palying but now that it is cold I have a squeak.
Old Jan 12, 2009 | 09:01 AM
AudiWorld Expert
Yes, loosen, pic recycled from the rear sport seat swap writeup
Old Jan 12, 2009 | 02:54 PM
Asicks2.7T's Avatar
Default I'm always stuck in NH :)
I'll try playing with it this weekend and let you know the outcome. perhaps I will need to take you up on your expertise. I'll ping you an email if I'm not able to resolve it.
Thanks for the help as always!
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 12, 2009 | 02:55 PM
Asicks2.7T's Avatar
thanks and yeah, the squeak/rattle is drivng me nuts.
hockey TT
Apr 8, 2009 05:10 PM
rdking
Audi allroad
24
Feb 23, 2004 09:53 PM
oneformula
Jul 8, 2003 02:25 PM
jose666
Sep 30, 2002 02:38 PM
orttauq
Audi allroad
Aug 18, 2001 07:28 AM
