Strong Gas Smell inside the car with the Heat on...
Old Jan 14, 2009 | 03:40 PM
Audifan1's Avatar
Default Strong Gas Smell inside the car with the Heat on...
what could it be?
I know I have to clean the heater motor (under the front passanger storage).
But why the strong gas smell? I drove today in a 5F weather with windows open. Priceless. You know... carbon monoxide is no joking matter.
Please tell me it's no Head Gasket Issue...
Help appreciated,
David
Old Jan 14, 2009 | 04:53 PM
paulroad's Avatar
Tech Guru
is is gasoline or is it carbon monoxide? which do you smell.
Old Jan 14, 2009 | 05:12 PM
Audifan1's Avatar
I smell Gasoline. Sorry my bad...
Old Jan 14, 2009 | 06:40 PM
98Quattro's Avatar
I thought Carbon Monoxide was odorless.
Old Jan 14, 2009 | 06:53 PM
Grapeking's Avatar
25 Year Member
You think correctly. Nice sig pic, too.
Old Jan 14, 2009 | 07:00 PM
squidix9's Avatar
No Bozos!
Default Maybe once every ...
...couple of months I get that too.
Doesn't matter if a full or empty tank/outside temperature or anything else it seems. I will pull up to a light and get a strong wiff of gasoline too.
No codes
Replaced all the vacuum lines
No apparent leaks
When it gets warmer (currently -6) in Spring I am going to inspect the filler neck and lines in that area.
Old Jan 14, 2009 | 07:07 PM
paulroad's Avatar
Tech Guru
Default and that is why I asked....
once BUJAK said a gas smell then he said a CO smell.
Methinks he is mixing up the typical exhaust smell. a Gasoline smell from the front of the motor with no visible leak is unlikely.
However and exhaust leak from the passenger sid exhaust: manifold, cat, O2 etc. would be an understandable cause.
Old Jan 14, 2009 | 08:12 PM
Press's Avatar
Fear the Miata!
i've yet to experience this
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 15, 2009 | 05:29 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default Gasoline does not contain carbon monoxide. My guess is the crimp on the fuel hose is weeping
my car does it in extreme cold, like this morning. Goes away after the engine is warm.
d6lc
Mar 12, 2018 09:00 AM
onalethata
Sep 24, 2007 04:59 AM
McKinneyA4
Nov 27, 2006 04:31 AM
Fargo
10
Oct 6, 2004 06:41 PM
RA121125
Jul 16, 2003 06:08 AM
