How many of you have r/r the coolant resv? Mine is cracking, leaking a little.
Old Jan 15, 2009 | 08:31 AM
Whitjr's Avatar
Old Jan 15, 2009 | 08:36 AM
audikillsbmw's Avatar
Member
Default Easy. Just use a turkey baster to pull out the fluid in there, then unbolt it/remove the hoses.
Pop the new one in, the fill it back up with fluid.
Old Jan 15, 2009 | 08:47 AM
EuroVWGTi's Avatar
nice idea Mcguyver. never even though about that before
Old Jan 15, 2009 | 08:56 AM
Member
Default Certainly more enjoyable than sucking it out with a straw :P
And no WOWdee, that is not what she said.
Old Jan 15, 2009 | 10:10 AM
SloopJohnB@mac.com's Avatar
Tech Guru
Tech Guru
Default Here! Also, don't forget to unplug the low coolant sensor...
if u forget, it can damage the wiring harness below it....
Old Jan 15, 2009 | 10:11 AM
Tech Guru
Tech Guru
Replace the @#$%$ spring hose clamp with a worm-type clamp
Old Jan 15, 2009 | 11:02 AM
Whitjr's Avatar
Thanks.. is this a common problem w/ our cars? High fail incidence? STFA doesn't say too much....
Old Jan 15, 2009 | 11:37 AM
JimmyC83's Avatar
Default and don't break that rubber T hose fitting!
sent me 20 miles to find another...oye!
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 15, 2009 | 12:12 PM
Whitjr's Avatar
Already had to r/r that one.... came back w/ a brass one -far superior to the OEM.
Old Jan 15, 2009 | 12:15 PM
JimmyC83's Avatar
that will tarnish/corrode, no? i got a ABS plastic one
