need help!!!!
Old Jan 15, 2009 | 12:56 PM
mileRUMA's Avatar
New Member
Default need help!!!!
I am having problem with heating. If somebody would be so kind to leave here codes in A/C control from 1999 audi A6 Q. Mechanic told me that somebody was playing with mine and everything is scr**ed up. in need for help pls.
Old Jan 15, 2009 | 01:20 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Perhaps if you told us what the problem is and what codes you are seeing?
What has been done in an attempt to fix? Output tests? Adaptation?
Old Jan 15, 2009 | 02:29 PM
mileRUMA's Avatar
New Member
Default Re: Perhaps if you told us what the problem is and what codes you are seeing?
some people say secret codes in A/C controller, they are all wrong.
It was a post about that before.
you can see these codes by pressing button above ECO on A/C panel and button With arrow UP same time then you can list all codes pressing left + sign.
1. System malfunction - displayed as a Diagnostic Trouble Code (DTC),
2. Digital value of Interior Temperature Sensor, in Headliner (G 86)
3. Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
4. Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
5. Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
6. Digital value of Outside Air (Ambient) Temperature Sensor
7. Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
8. Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
9. Delta value of Temperature Regulator Flap
10. Non-corrected specified value of Temperature Regulator Flap
11. Digital value of Central Flap Motor Potentiometer (G 112)
12. Specified value of Central Flap
13 Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
14. Specified value of Footwell/Defroster Flap
15. Digital value of Air Flow Flap Motor Potentiometer (G 113)
16. Specified value of Air Flow Flap
17. Vehicle Speed (km/h)
18. Actual Air Blower voltage (Volts)
19. Specified Fresh Air Blower voltage (Volts)
20. A/C Compressor (A/C Clutch) voltage (Volts)
21. Number of low voltage occurrences, non-transient
22. Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
23. Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
24. Cyclings of the switches, absolute non-fluctuating
25. Analog/Digital value, Kick-Down Switch
26. Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
27. Coding value
28. Engine Speed (RPM)
29. A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
30. Software version
31. Display check (all segments of A/C Control Head display light up)
32. Potentiometer malfunction counter, Temperature Regulator Flap
33. Potentiometer malfunction counter, Central Flap
34. Potentiometer malfunction counter, Footwell/Defroster Flap
35. Potentiometer malfunction counter, Air Flow Map
36. Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
37. Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
38. Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
39. Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
40. Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
41. Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
42. Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
43. Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
44. Vehicle operation cycle counter
45. Calculated interior temperature (internal software, in digits)
46. Outside (ambient) temperature, filtered, for regulation (internal software)
47. Outside (ambient) temperature, unfiltered, (internal software, in deg C)
48. Outside (ambient) temperature, unfiltered, (in digits)
49. Malfunction counter for speedometer (vehicle speed) signal
50. Standing time (in minutes)
51. Engine Coolant Temperature (ECT) in deg C
52. Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the "88.8" display. See chart below.
53. Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the "88.8" display. See chart below.
54. Control characteristics.
55. Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
56. Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
57. Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
58. Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
59. Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
60. Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
61. Software version (latest)
Old Jan 15, 2009 | 02:57 PM
mileRUMA's Avatar
New Member
If somebody who have 1999 a6 Q want to help i would be greatfull. I will call you and go over the phone with you to compare my codes with yours.
Old Jan 15, 2009 | 03:11 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Against my better judgement...
Maybe I'm missing something, but you really haven't posted your problem...or anything else that anyone on this board can use to help.
Again, I ask:
What symptoms are you experiencing?
Did you use VAG-COM to pull trouble codes?
Have you done output tests?
Have you done adaptation?
Old Jan 15, 2009 | 05:08 PM
mileRUMA's Avatar
New Member
Default Re: Against my better judgement...
Now Do You realy want to help????
On left side went blow hot air,
on winshield blow cold,
on the right side not blow enough.(warm)
I know what is the problem, that's why i am looking for somebody with same car so i can copy all adjustment from his car to mine.
Old Jan 15, 2009 | 05:33 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default It doesn't work that way.
The control unit handles it all.
I get the feeling that we aren't getting the whole story. I'd like to help, but I'm not about to run through all those numbers with you.
Old Jan 15, 2009 | 05:54 PM
thxguy's Avatar
Default I thought I would go and see the list on my car-
when I punch in the series buttons you describe- I get the number reading out on the passenger side temp display, but all that displays on the drivers side is C.
I ran through all the numbers up to 63 or so- all read C.
If you can describe in a more complete fashion where the results or the values of the paramaters are displayed- I can do it tomorrow.
Cheers-
Good luck.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 15, 2009 | 06:12 PM
tozoM8's Avatar
Tech Guru
Default You need to use Vag-com. The CC display is read only.
you won't be able to do anything with it.
Old Jan 15, 2009 | 06:20 PM
mileRUMA's Avatar
New Member
Default Re: I thought I would go and see the list on my car-
everytime when you punch + sign it will show on the left c on the right 01, 02, 03 etc. example: you hit + and it show c 01 then you hit recirc. button and then you can see other numbers like from 00 on left and 00 on the right side. if you hit fan control (+ or -) it will change from 00 00 to 02 55 max Anyway if you have time i can call you and tell you what to do and go over with you just to make sure that i have same parametars on my display as you.
