Uh oh.... No reverse all of a sudden...
Old Jan 17, 2009 | 09:22 AM
A6S4's Avatar
Default Uh oh.... No reverse all of a sudden...
Well, this a.m. I put the car in reverse -- and virtually nothing happened. It was like the clutch was slipping on a manual drive. Runs fine in all forward gears, but engine rev's and virtually no reverse movement.
Diagnoses? Suggestions? Dealer says some kind of module may need to be changed out. It's an A6 4.2 w/ 123K miles on it. Dealer also says may be in vicinity of $1500 or so....
Your help would be appreciated. TIA...
Old Jan 17, 2009 | 09:25 AM
p3u's Avatar
p3u
Member
Try clearing codes first, you never know.
Old Jan 17, 2009 | 10:24 AM
Press's Avatar
Fear the Miata!
that suxs....have you changed the trans fluid....ever?
Old Jan 17, 2009 | 10:39 AM
donp's Avatar
Have you had any CE lights with the "No power transmitted" code?
tozoM8's Avatar
Tech Guru
Default Blown F piston for reverse. Known problem for 01' 4.2 A6 A/S8.
<center><img src="http://pictureposter.audiworld.com/80919/dscn0007.jpg"></center><p>
Old Jan 17, 2009 | 12:36 PM
A6S4's Avatar
Default Thanks, guys -- will post result...
Yes, changed tranny fluid at about 65K and was taking it in next weekend to do again...
Not sure what the "F" piston is, but will inquire about that at dealer (trusted dealer and mechanic).
Actually, I think it is jealousy on the part of the A6, as we just brought home the "new" '06 S4, and it is getting all the attention...
Old Jan 17, 2009 | 02:19 PM
JLaws's Avatar
Default Unfortunately you will need a rebuild...
Happened to me and several others. Goes without warning. Fluid flush does nothing. The F piston is inside the transmission.
Old Jan 17, 2009 | 04:30 PM
A6S4's Avatar
I was afraid of that.....$$$$$!!!!!
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 17, 2009 | 04:32 PM
A6S4's Avatar
Is that why that call it the "F" piston..... F*&amp;^!!!
Old Jan 17, 2009 | 05:11 PM
tozoM8's Avatar
Tech Guru
Default It's not that bad.
$3500 out the door, just bring it over
