No heat at idle after some soft of coolant flush/drain/change/treatment? Here is fix
The heater core generally only gets pressure when the car is revved up, because it is a passive system (i think), if there is any sort of air pocket, it wont leave through the hose for some reason, and needs to be bled properly.
There are two coolant hoses on the firewall directly next to the battery for the heater core.
The right hose(outlet) has a bleed hole on it. The hose needs to be pulled part way out, until the bleed hole is exposed.. you can see the tiny hole in the pic, ignore the numbers i borrowed this pic
Once the hose is pulled out to the point of the little hole being exposed to coolant, rev the engine up to 3-4k for 3-5 minutes. There will be coolant loss, and YOU ARE NOT DONE at the first sign of coolant through the little hole.. Keep going. For a while. And have someone push the hose in while the engine is still revved up after 3-5 min. (be careful here, as it can be HOTTT).
IF THIS DOES NOT FIX YOUR PROBLEM, REPEAT.
I don't have the factory tool (VAG1274/8 and VAG1274/10) so I gently pressurize the reservoir and then slip the hose back over the bleed hole once a steady stream of coolant is coming out.
