what is the lowest profile tyre for a 16in wheel
Old Jan 18, 2009 | 01:54 AM
Enam's Avatar
Default what is the lowest profile tyre for a 16in wheel
currently have 215 55 16's,
want to put some lower profiles and sports suspension going forward.
would 205 45 16's work?
or would I need to put
205 45 16s in the front
and 205 50 16's in the rear?
with Koni Fsd and Eibacks (Audi 2.7T Q)
thanks in advance
Old Jan 18, 2009 | 05:10 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Here's a crazy thought: put the right size tires on
Your question has not answer. Wheel size dictates limits on tire size. All four tires and wheels should be the same. Rolling diamter should be as close to stock as possible.
Old Jan 18, 2009 | 05:58 AM
Press's Avatar
Fear the Miata!
4d4....why would anyone do that?
Old Jan 18, 2009 | 06:01 AM
audimonster100's Avatar
New Member
Default This could help.
<ul><li><a href="http://www.miata.net/garage/tirecalc.html">Click</a></li></ul>
Old Jan 18, 2009 | 06:03 AM
Enam's Avatar
Default Re: what is the lowest profile tyre for a 16in wheel
If possible use the stock 16 wheels with a lower profile tyre.
then run on Koni FSD...and some sport springs...
I wanto avoid the "tractor" wheel look...
Could I use a lower profile tyre then the current factory (215 55 16's)...
or would I encounter issues with the speedometer out of calibration?
Old Jan 18, 2009 | 06:11 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Sadly, I doubt that it will. Circumference does not seem to be a consideration.
4Driver4's Avatar
Tech Guru
Tech Guru
Do you understand that the profile number is percentage?
Old Jan 18, 2009 | 06:12 AM
4Driver4's Avatar
Tech Guru
Tech Guru
&lt;sigh&gt;
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 18, 2009 | 06:22 AM
Cargasm2.7's Avatar
You would negate the visual effect of lowering by reducing the sidewall.
Old Jan 18, 2009 | 06:28 AM
Press's Avatar
Fear the Miata!
tj....sandwich king....how's it going?
