brake pad light
Old Jan 18, 2009 | 10:31 AM
quicksilver 2.7's Avatar
Default brake pad light
Does anyone know which wire to ground out behind the instrument panel for the brake pad light?
Old Jan 18, 2009 | 11:36 AM
BernieBenz's Avatar
You want to turn it on or off?
Old Jan 18, 2009 | 01:47 PM
JimmyC83's Avatar
much easier to complete the circuit at the brake pad location, no?
Old Jan 19, 2009 | 05:20 AM
Default Re: You want to turn it on or off?
I did complete circuit at brake pad location. Light still on. I want to turn it off. Thanks.
Old Jan 19, 2009 | 06:24 AM
BernieBenz's Avatar
Default If you shorted out both pad sensors you have an open circuit somewhere else. Black electrical...
tape over the bulb is an easy fix.
Old Jan 19, 2009 | 05:45 PM
Default Re: If you shorted out both pad sensors you have an open circuit somewhere else. Black electrical...
Okay, I pulled the instrument panel Sunday just to check out the connections to the brake pad light. When I re-connected the wire harness and put the panel back in, the light went off. Could be a bad contact in the plugs. Will keep u guys posted.
Audiheavy
Feb 20, 2007 08:51 AM
AUDI TACHO
Sep 8, 2004 07:03 PM
zoomob
Jul 22, 2004 06:46 PM
grrttjn
Audi 100 / A6 (C4 Platform)
Mar 25, 2004 02:41 AM
PaulW
Nov 16, 2003 06:36 AM
