Power steering moaning and groaning after drive in low temps
New fluid is seldom a bad idea. If you haven't changed the fluid it might be worth a try.
Good Luck,
Steve
By the way, could a clogged screen also cause cold weather start no-power steering woes (daughters B5 A4)? Had the pump replaced on that one, but still have the same problem. It's a bear to steer for a couple of minutes, then just breaks loose while driving.
Thanks BernieBenz
