rear wheel bearing replacement questions - I'm in the middle of it now
Old Jan 18, 2009 | 07:35 PM
OOOOya's Avatar
Default rear wheel bearing replacement questions - I'm in the middle of it now
'99 A6 Avant
Can anyone confirm that the bearing is only a press [and corrosion] fit - no retaining circlips just like the bentley procedure exploded view? I see none, and with copious penetrating oil I can't get the bearing to budge. In fact, in trying I managed to find the weak point in FLAPS rental tool [evil grin]
The "head" of the forcing bolt sheared loose. It's made from a hardened all-thread with nut welded on one end with about 0.5mm of penetration. I pulled the threads and broke the weld with my man hands and a 1/2" breaker bar. Sorry no picture yet.
Anyway it looks like I'll be applying some heat to the cast carrier and I'd like to remove the ABS sensor - does the lead come off the sensor head or do I need to disconnect the entire length to thread the sensor out?
thanks for the picture Tony
<img src="http://pictureposter.audiworld.com/74843/thanks_tony.jpg">
Old Jan 18, 2009 | 08:56 PM
Li3ny's Avatar
The sensor just slides out....no threads.
Old Jan 19, 2009 | 02:57 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Default My experience with the front was that the hub shark and impact *almost* had...
...enough grunt to get the bearing out.
Heat is not needed, just a little impact. Use the tool to get some tension on the bearing, then tap it with a hammer. Store the new bearing in the freezer prior to installation.
Old Jan 19, 2009 | 05:36 AM
Kris Hansen's Avatar
Head Cat Herder
25 Year Member
Default This is why I have no problem paying my shop 1 hour of labor to replace wheelbearings..
it's the only thing I never attempt on my own.
Old Jan 19, 2009 | 06:35 AM
BernieBenz's Avatar
Do it right! Take the bearing housing to a press.
Old Jan 19, 2009 | 02:14 PM
OOOOya's Avatar
Default tried pressure, tapping with hammer, heat....an hour ago I gave in
and took the housing off the car, dropped it off at the auto shop a few blocks away. $30, thank you. Totally worth it. Just about to reassemble it now.
I ended up breaking the nut off the forcing screw 2 more times before throwing in the towel. Now I've gotta repair the rental tool again and return it so I can get my $$$ back.
rickyS4
Feb 6, 2006 05:29 PM
por911
Oct 30, 2005 02:44 AM
AaronBryan
Mar 26, 2005 06:03 AM
Chuckles2
Aug 31, 2004 08:12 PM
Garrett R.
Apr 11, 2004 04:16 PM
