Tips for changing out Pre-cat O2's? I went in there today to look at what I have to do.
Old Jan 18, 2009 | 09:25 PM
KillA6's Avatar
Default Tips for changing out Pre-cat O2's? I went in there today to look at what I have to do.
First question is from above or below? Seems like above for pass. and below for driverside.
Do I need to take the heat shield out on pass/driverside?
Best tools?
Also is it best to warm the car then take them out?
I spayed the O2's w/ PB blaster and I put an open end wrench on the pass. side O2 to see how much of a pain its going to be. Seems like the heat shield or turbo bolt might get in the way.
I did look for a write-up but couldn't find one.
Old Jan 19, 2009 | 03:43 AM
Chaddy's Avatar
Junior Member
Default Go in from above for both, parallel to the firewall with lots of extensions; might......
<center><img src="http://pictureposter.audiworld.com/76469/30_inches_to_o2.jpg"></center><p>....have to remove accordian hose. I can't remember if you need to loosen the heatshields or not, but you'll figure it out.
Old Jan 19, 2009 | 03:52 AM
4Driver4's Avatar
Tech Guru
Tech Guru
Penetrating oil is basically useless in this situation. Just warm the car up a bit.
Old Jan 19, 2009 | 10:14 AM
KillA6's Avatar
It seems to be a bit of an angel. Did you use an elbow joint on the extensions?
Old Jan 19, 2009 | 10:38 AM
TGK's Avatar
TGK
Its a PITA! If you don't have a lift, and a socked falls off....you'll never find it
Old Jan 19, 2009 | 12:03 PM
KillA6's Avatar
I have a budget lift. Its called tall jack-stands. lol I know the headaches of lost sockets.
Old Jan 19, 2009 | 04:37 PM
a62.7t4ceo's Avatar
Default Agree with Chaddy. Go in from top.
For driver's side: After you've removed the coolant reservoir and accodian hose, remove heatshield bolts (IIRC 5mm hex)and shift heatshield to the right. This will give you "enough" room to work. You'll see the EGT is right above the B2S1. You'll need a 7/8 socket. Use elbow joints, extensions, etc....you'll get to it. Expect to have a few scratches on your hands.
Old Jan 19, 2009 | 08:03 PM
KillA6's Avatar
Thanks all. Going to tough it tomorrow. I bought an O2 offset socket just incase.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 20, 2009 | 03:37 AM
Chaddy's Avatar
Junior Member
No, but some are wobble extensions - I recall having just enough slop in the extensions to do it.
Old Nov 9, 2009 | 05:05 AM
seopositive2's Avatar
I am searching webcam chat tips on google so i found your post so this is a very interesting find indeed. I will have to check it out when I get the time though. Thanks for the nice tips.
BrokenRocket
16
Apr 30, 2006 02:38 PM
washparkS4
12
Mar 16, 2006 02:32 PM
XcellR8edAudi
Jun 4, 2005 05:12 PM
Jason_S
Audi Original "S" Cars
Jan 4, 2005 01:32 PM
