GBW, still having Bentley Issues? try installing logged on as "administrator"
"Audiworld fanatic or Computername\GBW" with administrator rights in account settings is yes an "admin", but still gets lesser downgraded privileges which are hidden from typical user daily operation.
and then add more with install via XP "compatability mode", but while in Vista, by simply right clicking...
find the *exe/ msi file/ whatever's available to kick off the install, and follow these instructions
(BTDT obviously, LMK how it goes.)<ul><li><a href="http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/">XP/ other OS install modes...</a></li></ul>
I'm an administrator, running XP SP2 mode, UAC is turned off, I've downloaded the latest version of eBahn directly from Bentley's site. Of interest, running the program as administrator is checked, but it's greyed out....I can't change it.
and to add some audi content, what part are you looking up to "fix" on your car? :-)
I just want Bentley running on the computer I use the most...the laptop is in the basement and my XP box dosen't have a printer hooked up to it now. It would probably just be easier to go buy a cheap printer!
The actual message is:
"Component eztoolslib2.dll or one of it's dependencies is not correctly registered: a file is missing or invalid"
The dll is in the eBahn directory....thanks for the suggestions by the way....
* Make sure you are using the most current version of the eBahn software
* In most cases, you can simply use the Check Web For Updates feature to update the software
* Or Download the latest eBahn® Reader software
(from their site, many ppl have had this issue, they addressed it i assume in a latest fix)
but otherwise im out of ideas...that's where Bentley developers might need to step in...
their DLL files might not be compatible and will need assistance
you should google if anyone has had any luck installing a digital bentley manual on vista...
sorry i couldn't help more!
Then attempt to download the 3.1.0.7 version and see if that works. Other than than, I'm out of ideas. Bentley was closed today, I tried them...LOL
Thanks for your help and suggestions....
if it doesn't work then a forward system restore does not bring back current stuff either...(learned that the hard way the first time that feature came out!)
