OK, a litlle help please. a brief arhive search says other power steering fluids
Old Jan 20, 2009 | 11:43 AM
jbchinoca's Avatar
Default OK, a litlle help please. a brief arhive search says other power steering fluids
esp from Autozone comply with Audi and VW specs. Only problem, none of the containers list it. So, my friends, by specific name, which one complies?
Old Jan 20, 2009 | 11:54 AM
Grapeking's Avatar
25 Year Member
Why bother? Just go to your closest VW dealer and buy Pentosin there.
Old Jan 20, 2009 | 12:56 PM
BernieBenz's Avatar
Default No big deal, just don't use the auto tranny type fluids, must be a hydraulic service fluid...
The former are designed for high shear service and do not have the lubricity required for high pressure piston pump service. They do work well for low pressure vane pump systems. I've been using tractor hydraulic fluids in my Audis for 30 years.
Old Jan 20, 2009 | 03:58 PM
Maini's Avatar
Default I researched a lot when I was doing the change.. some people said the Mobile1 ATF can be used....
But I went with the Pentosin.. it cost me $40 for 2L shipped and I think it is worth it.. Audi has a particular reason for using that fluid and I did not want to risk my rack to question their engineering province Pentosin CHF 11s
Also use the following method to change the fluid... Make sure you take the resovior out and use a hose or compressed air to clean the screen.. the screen does not come out in the A6... I use a water hose and dried the resovior using a hair dryer...<ul><li><a href="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/psflush.html">http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/psflush.html</a</li></ul>
Old Jan 20, 2009 | 04:21 PM
Press's Avatar
Fear the Miata!
go to the vw dealer and buy the real stuff....
Old Jan 20, 2009 | 05:26 PM
jbchinoca's Avatar
Default My indy (same one for alll my C5 services, no pprior issues), told me that to just top up,
generic is fine, only need to worry when changing hoses, pump, or flushing. Just don't buy the Honda only one.
Old Jan 20, 2009 | 05:53 PM
Pete K (vegasguy)'s Avatar
Default Pentosin CHF 11.S.... Find a new service shop as that was BAD advice
A quick web search found this example..... not endorsing the site, just wanted to show you an example.<ul><li><a href="http://www.partsgeek.com/catalog/2000/audi/a6_quattro/steering/power_steering_fluid.html">http://www.partsgeek.com/catalog/2000/audi/a6_quattro/steering/power_steering_fluid.html</a</li></ul>
Old Jan 20, 2009 | 07:53 PM
Press's Avatar
Fear the Miata!
cheap at the vw place....so don't skimp
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 21, 2009 | 05:37 PM
jbchinoca's Avatar
Caved in and got it from VW Dealer. Even gave me a discount. $19.95 + tax.
ajg617
Jan 8, 2014 05:08 PM
SolidFish
May 27, 2006 01:39 AM
S_noob
Audi Original "S" Cars
Aug 29, 2005 08:48 PM
UrStage2
May 1, 2005 08:54 AM
godek
Audi 100 / A6 (C4 Platform)
Jun 3, 2003 07:35 PM
