a6 2.7 with smoke after warming up
Thanks
Chances are very good that you'll be perfectly fine. First, though, ensure your engine oil level is good - you probably lost more oil than you think, so double check that.
Next, clean stuff up as best you can; this will allow you to keep an eye on leaks and see if they continue.
Based on my own personal experience with this issue, your turbos should be fine. I had plenty of oil in my intercooler intakes, etc. and that was maybe 40k miles ag0 - and the turbos still run fine.
Next time you see the "smokescreen" pull over and slowly let the pressure out of your system, either by loosening the oil cap, or by pulling the dip stick, as you did today. Once the pressure it equalized, retighten the oil cap and leave the dip stick maybe 1/2 out so no more pressure builds. Once the oil is at normal operating temps you can push the dipstick back in all the way.
Also, during winter things inside the engine get cold and smoke is not an unsual sight.
