2000 A6 4.2 - lots of errors any chance someone can point where to start?
Old Jan 22, 2009 | 05:45 AM
frankinstyn's Avatar
Default 2000 A6 4.2 - lots of errors any chance someone can point where to start?
I have a friend that owns a 2000 A6 with the 4.2 who is having alot of problems right now and I really appreciate any help as to where to start the troubleshooting.
A little background...
- about 103,000 miles
- Timing belt most likely hasn't been done (havn't checked with the dealer records)
- Can't see how this matters but the steering pump is shot
Now onto the problems. When you start the engine it had a very very rough idle but no odd noises. When you give it gas it simply dies. I didn't try putting it into gear and didn't start it a second time. These are the codes that showed up.
I did clear the codes before I started it but the flashing engine light showed up almost immediately after I started it.
Thursday, 22 January 2009, 06:07:14
VAG-COM Version: Release 409.1-S
Control Module Part Number: 4D0 907 558 S
Component and/or Version: 4.2L V8/5V G 0008
Software Coding: 06752
Work Shop Code: WSC 02324
10 Faults Found:
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
16825 - Evap Emission Control Sys: Incorrect Flow - Intermittent
17551 - Load Calculation Cross Check: Upper Limit Exceeded - Intermittent
16502 - Engine Coolant Temperature Sensor (G62): Signal too High - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
16687 - Cylinder 3 Misfire Detected
16686 - Cyl. 2 Misfire Detected
16685 - Cyl. 1 Misfire Detected
16689 - Cyl. 5 Misfire Detected
Old Jan 22, 2009 | 05:53 AM
Boston Driver's Avatar
AudiWorld Expert
Default I'd guess the random misfires are bad coilpacks, but...
...that is only a guess. Go to the link below (Ross Tech Wiki Page) for more info on the various fault codes...<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">Fault Codes</a></li></ul>
Old Jan 22, 2009 | 05:54 AM
4Driver4's Avatar
Tech Guru
Tech Guru
I'd start by replacing the coolant temp sensor and checking for vacuum leaks.
Old Jan 22, 2009 | 09:07 AM
Devil_Inside's Avatar
Wouldn't a bad MAF do smth like that too?
Old Jan 22, 2009 | 12:33 PM
Default I was thinking the CTS too. Didn't see any vacuum line problems.
One thing I should have mentioned before was that he has had this issue once before (about two weeks ago) and it went away after he put some of that alchohol (water drier) stuff in the fuel. I told him for now to run (idle) it a little to see if it could just be more water in the lines.
silver7x
Sep 21, 2009 06:33 PM
4point2slc
Mar 22, 2007 04:07 PM
pch2004
Mar 22, 2007 02:38 PM
play-titleist
20
Mar 12, 2004 08:30 AM
2000 - A6Q
Jan 3, 2001 09:19 AM
