vag com
Old Jan 22, 2009 | 01:00 PM
jeramiea's Avatar
New Member
Default vag com
I have a 01 4.2 a6 and I want to buy a vag com system for it, but I dont know much about the tool. Is there only the ross tech one for $250? Or are there other options?
Old Jan 22, 2009 | 01:07 PM
RLG's Avatar
RLG
The RossTech software / cable will give you the most diagnostic insight
Old Jan 22, 2009 | 01:08 PM
4Driver4's Avatar
Tech Guru
Tech Guru
Default Contact Ross-Tech support and they will help you buy what you need.
There are other adaptors available on ebay and other places that can be used with the Ross-Tech software, but they only run in "demo" mode with most features disabled. They also have zero support.
Old Jan 22, 2009 | 01:13 PM
jeramiea's Avatar
New Member
Default Re: The RossTech software / cable will give you the most diagnostic insight
thanks guys, ross-tech it is
Old Jan 22, 2009 | 09:16 PM
Maini's Avatar
Default Here is an Option if you have a car that does not need CAN
As far as I know CAN started in 2002.. so you should be good with this.. I have been using this successfully..<ul><li><a href="https://forums.audiworld.com/a6/msgs/799446.phtml">https://forums.audiworld.com/a6/msgs/799446.phtml</a</li></ul>
Old Jan 23, 2009 | 07:04 AM
padog's Avatar
I use this same setup and it works fine for me also!!
Parsec
Q5/SQ5 MKI (8R) Discussion
23
May 2, 2013 11:52 AM
gilee_8
Jun 25, 2010 01:33 PM
lynel007
Mar 13, 2010 06:43 AM
Gibson6594
14
Jul 30, 2004 02:19 PM
