Help
Old Jan 23, 2009 | 05:25 AM
audi1121's Avatar
New Member
Default Help
Parktronic stopped working! Does anyone know which fuse this is? That was my first thought was to check the fuse, but the book doesnt list parktronic in the fuse list. Any other Ideas?
Old Jan 23, 2009 | 05:30 AM
Boston Driver's Avatar
AudiWorld Expert
VAG COM will tell you. See if your local AutoZone can do a scan for you.
Old Jan 23, 2009 | 06:29 AM
Devil_Inside's Avatar
Default Could be caused by a dirty or faulty back-up sensor. VAG-COM will be your best bet, but mine...
...is acting up as well, and I have a rear, right sensor malfunction. If ope sensor is bad, the entire system malfunctions. A new sensor is about $80 and it is not extremely difficult to replace as DIY. Do you hear an alarm when you put the car in reverse - constant beep for about 20 second?
Old Jan 23, 2009 | 06:37 AM
AudiWorld Expert
Default dirty rear sensor will cause system to give constant tone, malfunctioning sensor...
...will stop system from working (as would a fautly speaker or control module).
If a sensor has failed, or there is something wrong with the control module or speaker, the VAG COM scan will even tell you...it can even specify which sensor has failed.
Old Jan 23, 2009 | 06:42 AM
Default Well I have a malfunctioning sensor and I get the constant tone alarm... go figure >>
VAG-COM says:
Control Module Part Number: 8D0 919 283 P
Component and/or Version: arkingsystem A6 USA D03
Software Coding: 01166
Work Shop Code: WSC 02325
1 Fault Found:
01548 - Sensor for Parking Aid: Rear Right (G206)
37-00 - Faulty
Old Jan 23, 2009 | 07:18 AM
AudiWorld Expert
Default Oh, I thought it just shut off. Well, since he said his stopped working, my assumption is...
...it is not a faulty sensor then, but something with the control module.
Old Jan 23, 2009 | 07:28 AM
boostbuddy's Avatar
My bet is bad speaker (which happened on mine and VAG-COM found)
Old Jan 23, 2009 | 07:30 AM
Default The only way to tell is with a VAG-COM unfortunatelly. Audi1121, if you are in the area >>>
and don't have a VAG-COM I can help you with the codes. I am located in Woburn.
 Pouria Savadkouei
 Michael S. Palmer
Old Jan 23, 2009 | 07:40 AM
AudiWorld Expert
Default when mine malfunctioned, it was a pinched speaker wire...
..when I did not carefully install my rear shelf (for the sunshade installation). So basically, I had to remove and install the rear sunshade to repair the speaker.
You'd think Audi would make a little access hole/panel to get at those components...but you'd be wrong!!! Ugh!!!
IanManchester
VAG-COM Discussion
Jul 13, 2008 04:22 AM
Es4go
Dec 7, 2006 04:36 AM
BlackS4tt (Josh)
12
Nov 11, 2005 04:29 AM
BlackS4tt (Josh)
VAG-COM Discussion
Sep 1, 2005 07:33 PM
justwentgerman212
Oct 17, 2004 12:19 PM
