Transmission Output Seal Replacement ' 98 A8
Old Oct 14, 2003 | 09:19 PM
ForgedDaddy's Avatar
Default Transmission Output Seal Replacement ' 98 A8
Thanks Paul for the great technical reference. My brother and I were able to knock this out in about four hours, could've been faster if we knew exactly where dad keeps his tools.
Here's what's perplexing: While my leak was substantial enough to have caused a quite a mess over time, it seems as if the seal was in pretty good shape. Also, it almost appears as if the gear oil was leaking out through the middle of the output shaft, past the attachment bolt, into the CV joint cavity. From there it was flung out through the flange seal? It seems unlikely but I found more fluid inside the CV joint than would be suspected, and the grease was in good shape (hadn't somehow degraded into a fluid) It seems the only thing that keeps gear oil from escaping into the CV joint is a tapered shoulder on the attachment bolt, and it wasn't that tight when I pulled it off. Just a thought...(I added a bit of high temp sealant there)
What was still most amazing to my brother the helicopter pilot was the fact that the drive shaft was made of carbon fibre.
Andy
'98 A8
'87 Targa
Old Oct 14, 2003 | 09:32 PM
ryoung's Avatar
Elder Member
Default I believe '98 was the last year for the carbon fiber drive shaft;
per the Bentley, steel from '99 on. I guess cost would be the only reason to abandon such a weight savings.
Old Oct 14, 2003 | 10:58 PM
subtitled's Avatar
New Member
Default hmmm...my dealer told me that my 99 has the carbon-fiber ds..
they replaced it when hunting for my problem that I still have...
Old Oct 15, 2003 | 03:34 AM
PaulW's Avatar
When Hisport did his, that's what he thought too
Old Oct 15, 2003 | 10:18 AM
PaulW's Avatar
I'm almost positive that all A8/S8's had carbon fiber drive shafts
Mr. daniel makover
Sep 15, 2007 09:50 AM
I'm No Pro
May 30, 2007 07:13 PM
theraudi1
9
Nov 9, 2006 05:39 AM
shwndh
Apr 27, 2006 09:44 AM
CGATT04
Feb 2, 2005 05:10 PM
