s8 vented rotors?
Old Oct 25, 2003 | 08:18 PM
zamalek's Avatar
Default s8 vented rotors?
the dealer just changed my front rotors but they are solid looking shouldnt the s8 have vented rotors?the previous ones were not vented also.
Old Oct 25, 2003 | 09:21 PM
ryoung's Avatar
Elder Member
Default The rotor vents ...
into the hub of the rotor and out at the circumference, assisted by vanes in the rotor "sandwich". Ignore the slots in the face of this rotor,
but you can see vanes in this pic, and your rotors are almost certainly similarly vented.
<img src="http://www.stasisengineering.com/images/Brake_TS_Sub_2.jpg">
Old Oct 26, 2003 | 05:04 AM
zamalek's Avatar
Default Re: The rotor vents ...
randy,you mean those slots should not be seen on the outside but they are there?
Old Oct 26, 2003 | 05:30 AM
ryoung's Avatar
Elder Member
Default No, that's just a fancy version of a slotted (vented) rotor.
Your rotor should look like this pic. Note the "ports" when looking at the rotor from the edge and also the cooling vanes when the rotor is sliced in half. The rotor is a centrifugal air pump, pumping air from the center and venting it at the edge.
<img src="http://www.colemanracing.com/pics/pn370.jpg">
Old Oct 26, 2003 | 06:35 AM
zamalek's Avatar
Default Re: No, that's just a fancy version of a slotted (vented) rotor.
thanks randy for clearing this up . i thought my dealer put a8 rotors on my car cause my 993 had rotors with holes in them. thanks again. ralph 2001 s8 blk/blk.
mpollan
Nov 4, 2007 05:27 AM
thewatcher101
Jun 18, 2007 03:08 PM
bugzy SoCalEuro.com
Mar 23, 2004 05:18 AM
StopTech CustSrvc
Mar 20, 2003 06:42 PM
P. Bauer
NorCal Discussion
Jan 24, 2003 11:30 PM
