1998 audi a8 brakes
Old Oct 28, 2003 | 07:57 PM
kaynos's Avatar
Default 1998 audi a8 brakes
I have a rear wheel rotor that seems to be getting too hot.. Is this a common problem? Does this car have floating calipers that sieze? After a 200 mile drive, the wheels seem to be coated in brake dust. Doesn't seem normal to me, but I am unfamiliazr with the car. Car has 88K miles. Has anyone noticed the rotors getting pretty warm after short drives? < 4 miles?
Old Oct 28, 2003 | 11:17 PM
PaulW's Avatar
Default Your caliper is sticking
Do you use your parking brake? If so, it's not releasing.
If not, your caliper is sticking, probably from a torn boot on the caliper, maybe from this procedure here:
<img src="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/rbrakes7.JPG">
<img src="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/rbrakes8.JPG">
Versus using the brake tool shown here:
<img src="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/rbrakes14.JPG">
If that is the case, you'll most likely need a new caliper unless you can find a rebuild kit and somebody to do it.
pw
Old Oct 29, 2003 | 05:57 AM
skiracer's Avatar
Default If both sides are getting hot, the parking brake is sticking. If only one side, then you have...
a caliper issue. Audi parking brake cables can get road grime and corrosion into them and stick in the engaged or partially engaged position. Could also be an adjustment issue with the parking brake cable. Let us know what you find.
Old Oct 29, 2003 | 06:24 AM
ryoung's Avatar
Elder Member
Default Re: Warm rotors
Even after a 4 mile drive, the rotors do get pretty warm. The pads never completely pull away from the rotors (or you'd have too much free pedal travel when you go to reapply the brakes), and even the very slight drag heats the rotors.
You still may have a problem, though. After a long 200 mile drive, it's not unusual to see the front wheels coated with brake dust, but you should expect to see much less at the rear, and the left and right sides should be the same.
lucarelli007
A4 (B8 Platform) Discussion
Dec 1, 2011 07:32 AM
Audi_Quad
Jan 19, 2007 03:27 PM
dec1184
May 19, 2005 08:25 PM
gg117
Feb 6, 2004 02:44 PM
mwh
Jun 19, 2001 07:35 PM
