Timing Belt Parts List and Resources Links - Need input from the group
A8 (D2) 4.2 32V (ABZ) Timing Belt Replacement
Must do items - parts list.
Timing Belt
Timing Belt
Timing Belt Idler Pulleys (2)
Timing Belt Tensioner
Timing Belt Tensioner Pulley
Timing Belt Damper
Harmonic Balancer Bolt
Four cams seals
Body Pin (what is this - from Ski's list)
Water Pump
Water pump
Water pump gasket
Thermostat
Thermostat gasket
(Red) Pentosin coolant
Other items to consider - parts list
Serpentine Belt
Serpentine Belt
Serpentine Belt Tensioner
Seals
front crank oil seal
Hoses
Upper radiator hose
Lower radiator hose
Oil Cooler Seals
(Need parts list for this last)
Links / References
<a href="https://forums.audiworld.com/a8/msgs/27133.phtml">Waterloo's first A8 TB changeout, on escapA8's car</a>
<a href="https://forums.audiworld.com/a8/msgs/27207.phtml">Mr. Hyde & Igor (Paul & Floris) - follow-up to the above</a>
<a href="https://forums.audiworld.com/a8/msgs/36110.phtml">Serpentine Belt Removal.</a>
<a href="http://www.pccchicago.com/AudiTBtools.html">Huge Waterloo tensioning troubleshooting thread</a>
<a href="https://forums.audiworld.com/a8/msgs/27580.phtml">Ski's parts list</a>
<a href="http://www.audipages.com/Tech_Articles/enginemechanical/tbreplace0.html">Audipages ABZ (32 valve) TB Replacement Procedure</a>
(Note - this was done before the bumper removal procedure in the "Mr. Hyde & Igor" thread was developed)
Thanks for all the groundbreaking, Paul. Hopefully this will be a useful addition to the Audipages procedure, after we polish it up a little.
I did get all the parts in for the timing belt service. I ended up adding 4 items to your original part list:
2x - 026103085D Camshaft cover oil seals
1x - 4D0807300 Body Pin
1x - N 905 428 01Harmonic Balancer Bolt
I went by the procedure list you've sent me before.
Talk to you soon,
escapA8
Wendy,
I would like to order parts listed below for my 1997 Audi A8 3.7 FWD (Front Wheel Drive).
According to Paul this is a complete list of parts for a timing belt replacement on an Audi A8 4.2 Quattro. He is pretty sure these parts will also fit my car, but suggested to check with you if this list also applies to my car.
Please give me a call at your convenience so you can quote me your most recent prices and I can place an order.
I am looking forward talking to you.
Thank you.
escapA8
Part Number Item List Sale Price Required Qty Extended Cost
077109119E Timing Belt $178.00 $28.95 1 $28.95
077109246B Timing Belt Damper $149.85 $86.25 1 $86.25
077109244A Idler Pulley $97.40 $31.95 2 $63.90
077109243A Tensioner Pulley $157.60 $45.95 1 $45.95
077903137Q Serpentine Belt $88.70 $25.93 1 $25.93
078121113F Thermostat $28.70 $10.50 1 $10.50
077121004H Water Pump $295.45 $64.95 1 $64.95
078121043A Water Pump Gasket Included with water pump
Total $326.43
Wendy,
I would like to order the following parts:
2x - 026103085D Camshaft cover oil seals (2 x $2.50)
1x - 4D0807300 Body Pin (1 x $0.82)
1x - N 905 428 01Harmonic Balancer Bolt (1 x $12.30)
Total: $18.12
Adding Illinois sales tax:
US$18.12 Parts + 6.50% Sales Tax = US$19.30
Grand Total: US$19.30.
Regards,
escapA8
