Cabin full of condensation !
Old Nov 24, 2004 | 10:52 AM
S8Tan's Avatar
New Member
Default Cabin full of condensation !
Hi There, hoping you S8 gurus may be able to save me a trip to my local Audi stealer. The cabin fills with condensation and the inevitable misty screen and with the climate control set to clear the screen it has little or no effect. The most effective way I've found is to put the climate cont on to recirculate and that got me to a point where I could see again. Just looking for some advise as to why this may be happening and what I can do to correct it. i had the air con re gassed about 6 months ago and the condensation & steam only seems to be a problem in this recent colder weather although the car can sit on the drive for a couple of days and the rear window mists up with no one in the car.
All ideas welcome ! The car is 1999 facelift 40V S8
Old Nov 24, 2004 | 11:07 AM
skiracer's Avatar
Default Clear the HVAC drains! There is water sitting in the ducts and that is what is causing the fogging!
Go here and follow the directions, or give them to your mechanic.<ul><li><a href="http://www.audipages.com/Tech_Articles/heatac/exaporatordrains.html">http://www.audipages.com/Tech_Articles/heatac/exaporatordrains.html</a</li></ul>
Old Nov 24, 2004 | 11:09 AM
A8-911-Odyssey's Avatar
Junior Member
Default or just run your heat full blast for about 6 hours....
..worked for me. I dried out the whole car pretty quickly.
Old Nov 24, 2004 | 11:10 AM
skiracer's Avatar
Good temporary fix, but the problem will return if the drains are still clogged.
Old Nov 24, 2004 | 11:15 AM
S8Tan's Avatar
New Member
Default Re: Cabin full of condensation !
Thanks skiracer - I've printed off that article and I can guess what I'll be doing on Saturday morning! All the best S8Tan
Old Nov 24, 2004 | 11:25 AM
Greg66's Avatar
Read here:
https://forums.audiworld.com/a8/msgs/77847.phtml
Point 4 - the dehumidifier - is the key once the drains are cleared.
Old Nov 24, 2004 | 11:34 AM
Jkay's Avatar
Default Since you are clearing the hvac drains ...
you might as well clear the other nipples as well, as they cause big headaches too.
The two in the front wheel wells drain the cowl air intake, and if clogged will flood the interior of your car eventually as well.
The sunroof has four drain lines, one in each corner, and should be cleared as well, since you can imagine what happens when the sunroof mechanicals get too full of water.
Old Nov 24, 2004 | 12:34 PM
PaulW's Avatar
Default You could also have a bad damper motor
You say it clears better in recirc....is there still air flowing when not in recirc? Sometimes the damper motors go bad and they get confused and can't open fully. When you put it in recirc, it takes a damper out of the circuit that could be causing the problem.
You can check that with measuring blocks using vag-com.
But I would also check the evaporator drains first.
The gas pedal on the facelift car is slightly different than the procedure, but you'll figure it out.
And post some pictures of your car! We love euro spec cars!
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 25, 2004 | 04:35 AM
tomaudi's Avatar
Default Re: Since you are clearing the hvac drains ...
Roof drains: where are they and how do you clean them? I can find the forward drains and outlets but I can not find the two rear drains. Can I see them with the roof open or do I have to remove the headliner?
Thanks,
Tom
Old Nov 25, 2004 | 06:23 AM
Jkay's Avatar
Default Uncle Sven sez ...
Here are the things you need to know:<ul><li><a href="https://forums.audiworld.com/a8/msgs/76295.phtml">Sven_A8s tutorial on drains from October 8</a></li></ul>
M,Meursault
Q5/SQ5 MKI (8R) Discussion
May 22, 2018 10:05 AM
rez
May 20, 2012 06:56 PM
saabSean
11
Jan 24, 2005 09:36 AM
1fastcat
9
Feb 28, 2003 07:17 PM
kuthair
Jan 15, 2002 10:24 AM
