Braking Sound Dilemma
Old Nov 28, 2004 | 09:53 AM
CaseyH's Avatar
New Member
Default Braking Sound Dilemma
I replaced my rotors and brake pads in the front a couple months ago. When I'm braking around corners is the only time they squeal. I can't figure out why they would be sound-free when not turning but as soon as I turn the wheel, they start moaning.
Old Nov 28, 2004 | 01:43 PM
skiracer's Avatar
Everything tight and torqued properly?
Old Nov 28, 2004 | 02:17 PM
PaulW's Avatar
Default Is the brake dust shield interferring?
Try taking the wheel off and pushing it back about 1/4" and see if that solves the problem.
Old Nov 28, 2004 | 03:11 PM
GrA8ful S8's Avatar
New Member
Default My brake squeal had disappeared.....
I took the car into the stealer for routine maintenence, and told them about the typical (it seems from the forum) S8 brake squeal when reversing, so they "machined" the rear rotors to remove the "glaze" they said forms, and the noise is completely gone. Go figure!
Old Nov 28, 2004 | 10:16 PM
skiwi's Avatar
Default do they squeal with the brakes on or off???
when you turn a corner.
Old Nov 29, 2004 | 03:43 AM
matrixabc's Avatar
New Member
Default Re: Is the cailiper floating freely
I have the one with 8 pads on the front, and I think that when you turn, one of the pads just touches the disk(Rotor)???
Old Nov 29, 2004 | 04:54 AM
ryoung's Avatar
Elder Member
Stone trapped between dust shield and rotor?
Old Nov 29, 2004 | 07:35 AM
CaseyH's Avatar
New Member
Only with the brakes on and only while while turning left.
 Pouria Savadkouei
 Michael S. Palmer
Old Nov 29, 2004 | 10:21 AM
dimitristx's Avatar
Nice. I'll inform my dealer. I mentioned this problem this a.m. when I dropped it.
Old Nov 29, 2004 | 12:59 PM
dimitristx's Avatar
GrA8ful S8--thanks! 2x in the past the dealer did nothing; now, they're machining the rear rotors!
