Brake glue?!
I replaced my pads and did not have the adhesive, and they do occasionally ring (not squeak). This started after 3-4 months. I took the wheels off last weekend and everything looked fine.
I will try the OEM pads next time to see if they come with the adhesive. Can you buy it separately?
TYPE: Quieting Brake Pad Adhesive PROD. #0228
BENEFITS: Non-slip brake pad adhesive, which eliminates disc brake squeal and chatter, caused by brake pad vibrations. Forms tenacious film, which dampens and absorbs vibrations at the break pad caliper interface. Resists heat and moisture. Remains effective even under severe driving conditions.
PROPERTIES
Appearance Blue
Can Size 20 fl. oz.
Form Aerosol
Net Weight 14-3/4 oz.
Scent Solvent-like
PROD. # UNIT U/M WGT
022801 B8 1 doz Doz 16
022802 C8 2 doz case Doz 32
Click here for container information.
