Dash change between 98-00
Old Dec 1, 2004 | 10:33 AM
carmaster's Avatar
New Member
Default Dash change between 98-00
I was looking at the dash change between the 98 and 00 A8's. I see it is still the same size and the vents are identicle. But they change to configuration of the buttons and where the radio is. Does anyone know or where I could find to see if the connections are the same through this change or not? Because I'm wondering if I can swap the 98 center dash piece for a 00 dash piece.
98:
00:
Old Dec 1, 2004 | 10:46 AM
PaulW's Avatar
Default You can't, they are totally different
I did it when I did my Nav Plus install.....it took forever....you need a new cage behind the dash and everything.
Why would you want to do this anyways?
<a href="https://forums.audiworld.com/a8/msgs/49846.phtml">https://forums.audiworld.com/a8/msgs/49846.phtml</a>
<a href="https://forums.audiworld.com/a8/msgs/48149.phtml">https://forums.audiworld.com/a8/msgs/48149.phtml</a>
<img src="http://www.audipages.com/upgrades/nav37.JPG">
<img src="http://www.audipages.com/upgrades/nav38.JPG">
<img src="http://www.audipages.com/upgrades/nav39.JPG">
<img src="http://www.audipages.com/upgrades/nav40.JPG">
Old Dec 1, 2004 | 11:33 AM
KaMaKaZieP -ALUMIN8-'s Avatar
Default But isnt sawing fun?
<center><img src="http://pictureposter.audiworld.com/23719/dscf0130.jpg"></center><p>
Old Dec 1, 2004 | 01:07 PM
banal's Avatar
What's in the space under the ash tray?
Old Dec 1, 2004 | 01:09 PM
carmaster's Avatar
New Member
Default Re: You can't, they are totally different
thanks for the reply and the pictures. It sure does look like a lot of fun to do it. I like the 00 set up better then the 98. But I may end up sticking with the 98 version.
Old Dec 1, 2004 | 01:24 PM
space? Its just the ashtray opened..
Old Dec 1, 2004 | 01:31 PM
banal's Avatar
what about UNDER it (removed). any space/depth to mount something that comes out from the slot.
Old Dec 1, 2004 | 01:44 PM
Default Gotcha..
Well there is limited clearance under there. mabye 1/2"-1"
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 1, 2004 | 03:13 PM
tozoM8's Avatar
Tech Guru
Default Cutting is definitely fun!
<img src="http://pictureposter.audiworld.com/80919/dsc01194.jpg">
Old Dec 1, 2004 | 06:13 PM
AUDIrageous's Avatar
What about swaping a '99 streering wheel for a 97? I miss the vol. controls :-(
