Passenger Side Door Mirror Problems
Old Dec 2, 2004 | 07:38 AM
cpbetts's Avatar
Default Passenger Side Door Mirror Problems
Hi,
I have intermittent problems with retracting the passenger door mirror. Soemtimes it will work and others it doesn't and on wiggling the whole mirror a bit and maybe moving it by hand it seems to work. What could I check out ? Could the mechanism need cleaning? could it be a motor problem ?
Any guidence appreciated.
cheers,chris
Old Dec 2, 2004 | 07:42 AM
PaulW's Avatar
Default We don't have folding mirrors in the US
But I do recall a thread on this on tyresmoke.net....I believe it was a cut or intermetient open wire behind the mirror glass.
You should pop the mirror off and inspect the wiring, probably easiest to remove the mirror cap also.
Use the handle end of a plastic spatula that you can get at any home improvement center.
If it's cold out, it's best to take a hair dryer and blow some warm air behind the mirror for a few minutes so you don't break the plastic parts.<ul><li><a href="http://www.audipages.com/upgrades/chromemirrorold.html">How to remove the mirror glass</a></li></ul>
Old Dec 2, 2004 | 07:53 AM
KaMaKaZieP -ALUMIN8-'s Avatar
Anyway to add that to US cars?
Old Dec 2, 2004 | 07:56 AM
PaulW's Avatar
Default First, you would need the mirrors that fold
Then you would need the switch that tells them to fold....there is one extra position on the left/right/none selected button for the mirrors.....
Then you have to wire it up if there isn't a wire in place.
I was going to buy a set of folding pre facelift S8 mirrors from Germany a while back, but didn't win the auction....but did this research first.
markray
Q7 MK 1 Discussion
Sep 5, 2014 02:26 PM
rhskcdn
Audi allroad
Sep 13, 2011 07:15 PM
Straz85
May 20, 2006 04:59 PM
Follow it
Mar 23, 2006 04:25 AM
Ari_UK
Feb 10, 2003 10:54 PM
