Camshaft Oil Seal
Old Dec 3, 2004 | 07:40 PM
borden's Avatar
Default Camshaft Oil Seal
<center><img src="https://www.autohausaz.com/secure/PartImages/068103085A.jpg"></center><p>Another question.
I purchased 2 camshaft oil seals from www.autohausaz.com to get ready for the T belt change.
I just checked with audipages and it is not clear if this is the correct part.
THey had it under part number:068 103 085A which is different from the audipages part number while audipages calls for 077103487A.
Please see URL and pic.
WHat do you guys think??
Who ever replaced it, is this what they look like? what does etka say about this part number?<ul><li><a href="http://www.autohausaz.com/catalog/lookup_parts.cfm?VehicleID=1352562&amp;CFID=296190 &amp;CFToken=75719624&amp;Subcategoryid=5600">http ://www.autohausaz.com/catalog/lookup_parts.cfm?VehicleID=1352562&amp;CFID=296190 &amp;CFToken=757196
Old Dec 3, 2004 | 08:05 PM
skiracer's Avatar
Default That is a different seal- you need the one that looks like a square cross-section o-ring.
This one is further back in the stack, and shouldn't need to be replaced.
Old Dec 4, 2004 | 04:33 AM
borden's Avatar
thanks!
Old Dec 4, 2004 | 03:49 PM
backdoc's Avatar
New Member
Default Re: Camshaft Oil Seal
for the rear seals you need part #'s 077103487, and 077103487A. They are bright blue and made of rubber. The two rear seals on the right side of the engine are different sizes. the outboard one is the larger of the two. They are very easy to replace. The torx bolts are T-30. I did these this summer and got rid of a leak and smoking in the right front wheel well, not to mention a lot of stink.
Doug G.
97 A8Q 111k
nothing
12v V6 Discussion
Jun 28, 2008 01:25 PM
EuropaVin
Apr 6, 2008 08:29 AM
Boilermaker v1.8t
Dec 26, 2007 08:27 AM
gateway
Dec 23, 2003 07:10 PM
S4iscool
13
Feb 4, 2003 02:22 PM
