How accurate has the brake wear light been for you guys?
The pad warning light works by cutting a wire in the pads, which is why a bad connection can turn on the warning and why the warning should come on right away if the pads are actually worn. It's not like older designs which turn on the light when a wire in the pad grounds against the rotor.
Tom
