I just ordered the dash rings. What kind of glue should I use since the BISON is not available here.
Old Dec 8, 2004 | 06:35 AM
Mitaka's Avatar
Old Dec 8, 2004 | 06:43 AM
PaulW's Avatar
Default I believe super glue is used....anybody who has done this can confirm?
I know Jack did this, you have to be careful to keep it only on one side.....
Old Dec 8, 2004 | 06:57 AM
KaMaKaZieP -ALUMIN8-'s Avatar
4-5 dabs of Crazy glue around the back perimeter will do fine.
Old Dec 8, 2004 | 07:03 AM
A8CT's Avatar
Default I used "Goop" adhesive. I've never had good luck with Crazy glue and it's dangerously thin.
I was worried about it running onto the face of the gauges. Mine have been in for about a year.
Old Dec 8, 2004 | 07:13 AM
I would say that goop is a better alternative.
Old Dec 8, 2004 | 07:29 AM
skiracer's Avatar
Default I would use something a little more flexible than super glue......
The expansion/contraction of the rings due to thermal changes could be enough to fracture the super glue. A really good rubber cement or a good silicone adhesive would be better IMO.
Old Dec 8, 2004 | 08:13 AM
borden's Avatar
Default Used Silicone --Goop will work as well, I think
the problem with crazy glue is that if you get it on the glass, you are screwed . There is no way to get it off. Someone on a4 forum I think drop some on, then tried to remove it, making even bigger mess.
Old Dec 8, 2004 | 01:25 PM
tozoM8's Avatar
Tech Guru
Default Be careful with the crazy glue, it contains cyanoacrylate, you can use it only in ...
well ventilated areas. The fumes will fade the plastic.
<img src="http://pictureposter.audiworld.com/80919/vw_cluster_5.jpg">
 Pouria Savadkouei
 Michael S. Palmer
Old Dec 8, 2004 | 05:09 PM
TSHong's Avatar
I used super glue as well.
Old Dec 8, 2004 | 07:15 PM
bA8's Avatar
bA8
Superglue must be used sparingly. It can get white and crusty
