Part number needed: high point bleeder screw. Does it come with the gasket?
Old Dec 10, 2004 | 05:49 PM
borden's Avatar
Default Part number needed: high point bleeder screw. Does it come with the gasket?
<center><img src="http://pictureposter.audiworld.com/75069/gunk.jpg"></center><p>
Thanks
DM
Old Dec 10, 2004 | 06:50 PM
skiracer's Avatar
O-ring, and a new bleeder screw comes with one.
Old Dec 10, 2004 | 07:32 PM
escapA8's Avatar
My dealer told me I would have to buy the set: most of what you see in the picture. US$17?
Old Dec 11, 2004 | 04:24 AM
borden's Avatar
Default anyone with ETKA--Part number please!!
That is great, does anyone has a part number though??
Thank you once again.
DM
Old Dec 11, 2004 | 12:31 PM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default We looked for that once before, I don't think it's in ETKA
I'll try to look for a link on that, when I go upstairs to the desktop. I think we came up with an alternate source, and I'm pretty sure I bookmarked it. I'm on the laptop in the den, watching college hoops, right now.
Old Dec 11, 2004 | 01:08 PM
borden's Avatar
Default Re: We looked for that once before, I don't think it's in ETKA
I need the part for the bolt, not the gasket!
THanks
DM
Old Dec 11, 2004 | 03:16 PM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default Doh!
What's the bolt look like? Is is not something you could get at a good hardware store, that has a good selection of metric stuff?
That's not a separate part in ETKA, either, just like the o-ring.
I just emailed you the screencap of the ETKA plate. Hope you have a high speed connection.
Old Jun 28, 2013 | 11:38 PM
KEVOZS8's Avatar
Thanks
DM
Do u Have the part number ? i didnt get it from ETKA
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 30, 2013 | 10:25 PM
twentysevenlitres's Avatar
Tech Guru
You won't get just the screw.
Part number for the whole bleeder is 4D0819159 (Audi calls it a "connecting pipe" just so it's easy to find on a parts list!).
List is $70, so $17 is a good deal (unless the dealer was mis-heard ) - also available on Ebay from the UK a8 parts specialist.
However, the most common fault with these is a failure of the o-ring seal.
You can replace these with a common o-ring available from plumbing store (or hardware plumbing dept) or bearing specialists.
Size is: 7/16(O.D.) x 3/32(t) X 1/4(I.D.).
Only use Nitrile or Viton, NEVER Silicone o-rings.
Buy a small tube of Rubber Grease while you're at it to lubricate the o-ring when you screw the bleeder-screw into the housing - if not available from hardware, try an auto parts store.
Good DIY available here:
http://www.audipages.com/Tech_Articl...eplacement.htm
I've done this mod myself... Works well!
Old Jul 1, 2013 | 12:41 AM
KEVOZS8's Avatar
Thank you For the info ! i will try it !
