Rear wheel/locking judder on a8 quattro
Old Dec 11, 2004 | 05:31 PM
icedillon's Avatar
New Member
Default Rear wheel/locking judder on a8 quattro
can anybody enlighten me as to wat is causing this? oil level for rear diff is fine, mounting is ok too!
It only happen when I do a full lock and take off, at speed it is ok, only happens when taking off or at slow speeds! My one is a 95 4.2 4 speed auto UK spec. SOmebody told me the clutches in the diff are locking up against each other?? make sense to anyone?? tyres seem ok aswell
Old Dec 11, 2004 | 06:01 PM
KaMaKaZieP -ALUMIN8-'s Avatar
Default Do you happen to have the ability to manually lock the rear differential?
In my 95 Audi A6 i had a button that allowed for manual lock up of the rear diff.. It created the same exact symptoms you mentioned. If you do then your switch might be stuck.
Old Dec 12, 2004 | 07:53 AM
PaulW's Avatar
That's the torsen differential, at low speeds and full lock steering the wheels skip a little
Old Dec 22, 2004 | 11:03 AM
icedillon's Avatar
New Member
Default Re: That's the torsen differential, at low speeds and full lock steering the wheels skip a little
ok, it never did that before, so what do I need to replace?? the rear diff??
Old Dec 25, 2004 | 03:24 PM
icedillon's Avatar
New Member
can someone tell me where this torsen differential is??
Old Dec 28, 2004 | 02:33 AM
icedillon's Avatar
New Member
Comeon guys! someone give me an idea where this torsen diff is or is it the rear one??
Old Dec 28, 2004 | 02:50 AM
icedillon's Avatar
New Member
Default Re: I am quite confused as to what needs changing and where this torsen is??
Is the torsen diff in the rear differential?
1995 A8 4.2Q Uk spec 4 speed auto
Old Dec 28, 2004 | 03:01 AM
icedillon's Avatar
New Member
Default Re: The A8 has no torsen differential!
the rear torsen was replaced after the V8 in 1994 with the introduction of the A8 by an EDL which I have no idea where is or how it works??
can someone explain??
 Pouria Savadkouei
 Michael S. Palmer
RGW
Apr 21, 2007 04:36 AM
coupe d'mike
Sep 11, 2006 08:32 AM
quattro20v
Audi Original "S" Cars
Mar 31, 2006 07:07 AM
samm
Audi 100 / A6 (C4 Platform)
Dec 21, 2002 09:55 AM
Helen
Misc. Models Discussion
Feb 7, 2000 05:39 AM
