steering rack or inner tie rod?
Old Dec 13, 2004 | 08:04 PM
Nasti's Avatar
New Member
Default steering rack or inner tie rod?
I did all control arms and links last month but held off on the tie rod ends because I ran out of time (and they seemed fine). I just checked for play in the front wheels and I'm getting a clunk from the back end of the inner tie rod. It seems to be behind the innermost boot. Is this a steering rack problem or inner tie rod?
Old Dec 14, 2004 | 05:31 AM
skiracer's Avatar
Most likely the inner tie rod. If the rack fails, you will know it by the puddle :-)
Old Dec 14, 2004 | 10:24 AM
Nasti's Avatar
New Member
Default Easy to replace tie rod?....
Do I just remove the boot clamps - pop the outer end - slide boot outwards - and unscrew the tie rod from the rack with likely a crows foot. I don't see much detail in my Bentley's.
Old Dec 14, 2004 | 02:12 PM
Audis or VWs 4Life's Avatar
Not hard but you will probably need an alignment afterwards....
halik
17
Aug 3, 2014 09:02 AM
JacobB
Aug 10, 2007 05:18 AM
RootMachine
9
Oct 29, 2005 12:47 PM
beep-beep
Audi 100 / A6 (C4 Platform)
Aug 10, 2005 04:26 AM
saxonyron
Dec 2, 2003 05:56 AM
