2001 S8 Running Too Hot
it seems to heat up right away and sit at the "normal" line on the gauge for a little bit, then start slowly getting too hot. now on every drive to work/home it sets off the warning light. but it hasnt actually gotten all the way to the right ... 'H' though.
The fans are both working properly, the coolant level is good, the radiator is hot, oil level good. this leads me to believe its the water pump...
tests i could do to determine what it is, and opinions please...
But with your description, I'll be you $100 it's the thermostat.
They fail on the 40 valve motors high and with exactly the same symptom as you have.
Get the timing belt done at the same time (and everything that goes with it). I have not done it on a 40 valve, but it's easier than a 32 valve.
pw
now i just drove it, and it actually overheated. i had to park until it cooled down. and this time the radiator felt cold, except on the very end of the driverside, it felt hot.
what is all involved in changing the thermostat?
i havent gotten my repair cds yet.
You'll need to do this, or just have somebody else do it, make sure they have the tools!<ul><li><a href="http://www.audipages.com/Tech_Articles/enginemechanical/tbreplace0.html">Similar procedure, not as hard</a></li></ul>
there was also a clicking noise, like something turning on and off near the cowl when the hood was open. from the area where the auxiliary water circulation pump is located in the pictures at the link from audipages.
The clicking noise is most likely one of your HVAC dampers, but not sure. Or it could be your aux water circ pump, which runs all the time.
well i might do this myself, so where can i get those specialty tools? i dont suppose i can get them asap and do the job today/tomorrow?
the dealer has the parts in stock, and i have the weekend off.
Here's the tools you'll need and an A6 4.2:
This one goes into the block and locks the crank shaft in place....
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/40v1.JPG">
I don't know what this does, but the Bently would show it.
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/40v2.JPG">
I don't even see the thermostat, but I know it's there....this is the cam locking device for the 40v motor.
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/40v3.JPG">
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/40v4.JPG"><ul><li><a href="http://www.zdmak.com/wbstore/main.asp?LowCt=0&action=cat&cat=AUDI%20TOO LS">Here's a place to get tools, I have bought from him before</a></li></ul>
