Paging PaulW...bluetooth install help!
Old Sep 27, 2005 | 04:18 AM
Boston Driver's Avatar
AudiWorld Expert
Default Paging PaulW...bluetooth install help!
I sent you an e-mail, but figured I would try you here as well.
I am installing a bluetooth kit (HCB-30) in Jmacs4.2's A6. It was taken out of his former car, and I do not believe that he has the installation instruction book. First, I wanted to confirm the wiring:
Red - constant power (with integrated fuse, but I am probably going to switch that to an inline fuse)
Blue - ignition powerBlack - negative ground
Yellow - mute
Is this correct?
The other question I have is whether or not the yellow Mute wire works well with the Audi head unit. I read on a support forum (I think from the UK) that the yellow wire sometimes does not carry enough current to trip the mute function in radios. Since you have the same setup (although somewhat modified with your hangup cup), does the yellow mute wire work well with your factory head unit?
TIA for your help!!!
Old Sep 27, 2005 | 04:56 AM
PaulW's Avatar
YGM
Old Sep 27, 2005 | 05:01 AM
AudiWorld Expert
Thank you!!!
quattrogirl
Aug 29, 2008 04:20 PM
A6turbo530
Mar 1, 2006 05:23 PM
Boston Driver
Sep 27, 2005 06:39 AM
ronniew81
Sep 17, 2004 10:51 AM
viks007
Feb 19, 2004 08:16 AM
