axle, cv removal
Old Oct 3, 2005 | 04:00 PM
A8CT's Avatar
Default axle, cv removal
I actually had a little trouble finding this in the search so this is for the next guy:
Axle bolt is a 17mm hex. I got a 1/2" impact version which didn't work. Used an allen wrench with a breaker bar (1" pipe). Make sure you take off the wheel, remove the center cap, reinstall the wheel, and then loosen on the ground.
Do this first !
Bob
Old Oct 3, 2005 | 04:11 PM
marcodant's Avatar
Junior Member
Default lol glad you got it off. I pulled my front shock off again
tonight and dug around again. I also repalced the bolt that hold both of the upper control arms together with the orginal one because it seems that the new one that came with my kit was just a slight smallef in diam.. Not sure if it is fixed yet. I should know more tomorrow. I drove about 30miles tonight and so far so good. I will keep you posted. I think you also stated you had the same type rattle.
Old Oct 3, 2005 | 04:16 PM
PaulW's Avatar
Default I didn't think you would get it off with an impact
I find things that are really stuck rarely come off with an impact.....you need that huge breaker bar and the wheel on the ground.
Old Oct 3, 2005 | 04:36 PM
A8CT's Avatar
Default It's funny you say that because this is first time I've been stuck.
It's been tested on a few crank pulley bolts and I just did two axles on a Lexus a couple of weeks ago. These were on a lot tighter though, I didn't stand a chance. I wound up standing on the breaker bar !
Old Oct 3, 2005 | 04:40 PM
A8CT's Avatar
Default no, I think it was someone else who had the rattle. I've been spared that misery in the ones
I've done. I have been using a torque wrench on every nut/bolt and doing the final torquing down on the ground after bouncing the car up and down a few times.
Old Oct 4, 2005 | 03:41 AM
JimR's Avatar
AudiWorld Uber User
25 Year Member
Default You need a 5' section of 1-1/2" Sch.40 pipe, to add to your breaker bar.
Give me a lever long enough and a fulcrum on which to place it, and I shall move the world.
--Archimedes
5' of 1-1/2" Sch 40 means no standing on the breaker bar.
I actually have a 2' piece and a 3' piece with a union. Gives me more flexibility for other needs.
Old Oct 4, 2005 | 04:30 AM
A8CT's Avatar
Now that's a breaker bar ! Mine is about 18".... the girls love it !
Old Oct 5, 2005 | 09:20 AM
ex-a8drifter's Avatar
Default I had the rattle....thats a good point about the bolts. Maybe I'll get Audi OEM bolts instead of
the Meyle ones in there now.
 Pouria Savadkouei
 Michael S. Palmer
UrS4boy
Audi Original "S" Cars
Mar 16, 2013 11:25 AM
The Frenchy
16
Mar 28, 2012 01:46 PM
mosmoe (OPG)
9
Nov 11, 2006 05:58 AM
AudiCraig
Audi 100 / A6 (C4 Platform)
Jan 18, 2005 05:13 AM
escargot
Dec 26, 2003 01:58 PM
